Slight "groan" in rear end
Old Dec 11, 2012 | 03:20 PM
TX_BB's Avatar
Hey everyone!
I've searched and have come up short on finding anything, so my appologies for starting this thread if it has been covered.
My '09 Tech FWD (50,000 miles) has developed a low/deep sounding groan in the rear end. It presents itself at 30 MPH, and gets slightly louder all the way through 80 MPH. To me, it sounds like a wheel bearing has gone out, or is starting to go out (I've had wheel bearings fail in past and know what they sound like), however, 2 Acura dealers and my local shop have ruled out the wheel bearings. The local shop even got out the stethoscope, but nothing could be found (although they CAN hear it).
They've checked everything from tires to a sticky caliper. Tires are brand new, car is in line, brakes are good.
I've read threads about a prop shaft, which describes the sound I have, but I don't have the SH-AWD, so it can't be that.
Any thoughts, suggestions or similar issues?
Thanks for all your help!
Old Dec 14, 2012 | 03:48 PM
TX_BB's Avatar
Anyone???
Old Dec 28, 2012 | 12:16 PM
TX_BB's Avatar
Bump
Old Jan 14, 2013 | 01:51 PM
adam38's Avatar
Although wheel bearings on Hondas, especially at that mileage, dont typically go bad, that still makes the most sense. If the noise was there before you replaced the tires, then yes....rule the tire thing out. But wheel bearings can be odd in their behavior, and you cant really always check their condition with just the car in the air and spinning the wheels, even with a stethoscope. They usually have to be loaded with the weight of the vehicle on them to get them to make the certain noises that they can make.
Old Oct 30, 2013 | 05:52 PM
seans5's Avatar
Sorry to revive a thread that's old, but I'm a new owner of an 09 TL Tech (not SH-AWD) and have the same type of noise you've experienced. Mine is evident between 35mph-45mph and then goes away completely. It's definitely from the rear of the car and sounds like a lower pitched dull roar or groan, as you describe.
I thought it was my old tires, but I replaced them today.
Were you able to pinpoint the issue on your TL? Thanks!
Old Oct 30, 2013 | 09:43 PM
jayare627's Avatar
I have a 2012 AWD and have noticed this with in the last week on the highway. I already had the prop. shaft fixed for the noise it was making. You are correct that it's like a dull roar, mines a little higher, between 40 and 50mph. Plan on jacking it up this weekend and checking the wheel bearings. Let me know if you end up taking it in and find anything out.
Old Nov 6, 2013 | 09:08 PM
seans5's Avatar
Just got my car back from the dealer today. My problem was, indeed, a wheel bearing. The dealer didn't seem convinced about the diagnosis until they used a stethoscope. The noise they picked up on was very faint, but it certainly wasn't at 45mph. I guess that bearing problems typically get louder at higher speeds, which mine did not - this also made the dealer question whether it was a bearing problem.
But, they replaced it today under the power train warranty and the the problem is completely gone! Hope that helps you diagnose your problem as well.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
marcelft
Jul 10, 2018 06:17 PM
wilztlxs
Dec 1, 2015 09:16 AM
o8 ENVII 8o
Nov 30, 2015 04:23 PM
