Remote help
Old Jan 27, 2013 | 01:14 PM
Westside_TL's Avatar
Remote help
i have a 2011 tech pack tl....my wife mistakenly wash my pants which had my keys in it...when the cylce finshed i found them and tested it with no problems...the next morning though it said i had to insert in the slot to start and non of the remote functions would work, including locks, is there a way to fit this or i have to just buy another? if i had to get another then where from?...thanks for any help
Old Jan 27, 2013 | 01:19 PM
Treblig's Avatar
Have you check the status of the remote battery? It may need replacing. Just a thought.
Old Jan 27, 2013 | 01:37 PM
no how i do that?
Old Jan 27, 2013 | 06:46 PM
Treblig's Avatar
When you press a button on the remote, there is a little red light on it should should light. I am not near my remote at the moment, but if the battery needs changing, you would need to pry the remote open to access the battery.
Old Jan 27, 2013 | 07:22 PM
no lights come on
Old Jan 27, 2013 | 08:22 PM
Treblig's Avatar
If no lights my guess would be that the remote is either "toast" or you need a new battery. With it getting wet, it might be done. But with it working right after the wash, it may very well be the battery.
Old Jan 27, 2013 | 09:31 PM
what part i need to pry open?
Old Jan 27, 2013 | 10:24 PM
MoAbbas's Avatar
moabizzi
pull the key portion off the remote, put a quarter in there and twist, should pop right off.
Battery CR2032
side note: the inside of the key got real dirty, maybe i should clean it.
Old Jan 28, 2013 | 12:41 AM
oc48bound's Avatar
I would recommend pulling out the battery and leaving apart overnight to make sure there is no moisture remaining in the key fob. Then install a new battery and cross your fingers it isn't fried. I think these fobs are pretty pricey. Good luck!
Old Jan 28, 2013 | 03:46 PM
Battery CR2032
thanks hope it works.......fyi it doesnt look as rough as that one though lol
datadr
Mar 23, 2016 01:39 PM
eastcoastguy
Oct 29, 2015 03:00 PM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
saturno_v
Sep 27, 2015 08:13 AM
