OEM or Acura windshield?
Old Dec 23, 2011 | 03:04 PM
misu's Avatar
Just got a nasty crack in the windshield (2012 TL) and I was quoted around $300 for OEM or $700 for Acura glass. What will I be missing if I go with OEM? With all the light sensors up front I'm worried that OEM will mess with the sensitivity but then again $300 doesn't sound that bad.
Is the windshield the same as the 2009? Will I get a lower quote if I lie on the year?
Old Dec 23, 2011 | 06:14 PM
macguitar's Avatar
The 2012 Acura TL has an new, upgraded windshield with twin-layer acoustic glass. Ensure the OEM replacement is also twin-layer acoustic glass or the noise levels in your car won't be the same.
You can read about it here:
http://www.hondanews.com/channels/ac...-acura-tl-body
ACOUSTIC WINDSHIELD
Special acoustic glass is used on the TL windshield to help reduce wind noise. Tuned specifically to attenuate wind-noise frequencies, the windshield uses two layers of 2 mm safety glass with an in-between layer of a transparent elastic acoustic membrane for a total thickness of 4.5 mm. The windshield (like the side windows and 5 mm thick rear window) is UV light absorbing. The acoustic windshield (in conjunction thick side windows) helps position the TL at the top of its class in wind-noise performance.
Old Dec 23, 2011 | 06:27 PM
lji's Avatar
lji
Mac, the acoustic glass has been present on the 4G since day one.
Old Dec 23, 2011 | 07:36 PM
TLtrigirl's Avatar
3G TL/2G MDX Owner
is the OEM glass the EXACT same specs as the acura badged glass (ie manufactured by the same company with the same codes on the label?
if you look at the windshield on the car right now there is a manufacturer's name with a bunch of codes. you can get the same windshield without the "acura" badge on it for significantly less.
it was established in the 3G forums that AP tech makes the windshield for the 3G TL. confirmation of the codes on "label" were the same as the original "acura" glass. i know a different company makes the windshield for the MDX (agc automotive).
so if you can get the exact same windshield less the "acura" badge...then you'll know its the same.
Old Dec 23, 2011 | 10:33 PM
macguitar's Avatar
Oops, I stand corrected. When I saw the 2012 TL intro video, I remember them saying they made improvements to further quiet the interior. I thought it was the windshield because that point was in the link above, but now that I read that link even further, these were the improvements for 2012:
For 2012, the use of noise insulating foam has been expanded to include the roof separators. In addition, a new body sealing compound and improved weatherstripping design help reduce high frequency noise by 3 dB within the TL's interior.
Thanks for the correction!
Old Dec 24, 2011 | 08:02 AM
TinyRK's Avatar
Autofahrer
misu,
check if your insurance covers cracks.
I had 2 bad chips and I told them, after they tried to fix the chips, that I want an OEM and they paid for it, since the car was so new.
Anyways,
I'd go with the cheaper one if insurance don't cover it, since you'll might end up having another crack and then you'll be pissed.
Old Dec 24, 2011 | 01:48 PM
misu's Avatar
Deductible is more that both so I'm paying for it, I'll make sure the oem one is the same quality before I go with that option, thanks all
Old Dec 26, 2011 | 03:25 PM
RDX guy's Avatar
The only negative experience with glass replacement a friend of mine had on his TL was the OEM glass didn't come with the 4" of tint across the top. He actually went back and had them swap out for the Acura glass.
csmeance
Jan 7, 2026 06:25 PM
rseb4agze
May 3, 2016 07:41 AM
handsom-hustla
Nov 13, 2015 05:04 PM
nanos
Nov 12, 2015 08:41 PM
MyKids&Cars
Sep 1, 2015 12:53 PM
