Noticed my two exhaust tips aren't even
the passenger side one is a little lower than the other, about quarter an inch lower. took it to the dealer, they lifted it up and showed me since the two tips were all connected thru one pipe and there is no way to adjust it unless they get the permission from me to remove the whole thing and bolt it back on again and even so they didn't believe it'd help much. i decided to leave the way it was, i don't want them to messed up my chasis and frame. anyone else notice this? i've seen couple TLs on dealers' lot having the similar issue. these are for FWD models only.
Yea, It's Me!
1 - Unbolt the system and try to realign it. There's not much play if it needs twisting. If one is higher than the other, they may be able to adjust by slightly bending one of the hangers welded to the under body.
2 - Heat it with a torch and bend it. Not desirable! But works.
3 - Replace it.
If it bothers you, then have them fix it. If not it will be one of those niggling little things that will drive you nuts and eventually you will kick yourself in the butt for not getting it taken care of. Me? I would push to have them replace it if they can't adjust it. It may have to go to Acura as a warranty issue. The dealer won't replace it out of the goodness of their heart. Good luck!
I am Mr. A-Type personality. I could not stand it if the pipes were uneven. There are basically 3 ways of addressing the issue.
3 - Replace it.
3 - Replace it.
Yea, It's Me!
Stop the Acura dealer in person, ask for the service manager and "be polite" tell him/her that you have been in before and wasn't satisfied with what you were told. Tell them that you have looked at the cars on the lot and they all have aligned exhaust tips. Ask them to replace the rear exhaust system so your car looks like the rest of the cars on the lot.
If you don't get satisfaction, ask for contact information for the regional Acura representative as well as Acura USA. Contact both and express that all you are asking for is that your car looks like Acura intended.
I'll really be surprised if you have a hassle. The reason you may have an issue with the dealership is because they need a cut and dry resolution to get reimbursed back through Acura since it should be a warranty issue.
Good luck and keep us all posted!!!
Just my experience but fwiw I try not to take a car in for an issue that they can easily say "it's normal" during a long weekend. Everyone is looking forward to a long weekend and some just kinda lollygag around until their shift is over. Just my experience with previous cars.
i scheduled to bring it in next Tuesday. i spoke to the service manager, he said the last time they didn't unbolt the whole exhaust system, they just tried to tweaked it w/o removing the whole thing. but this time they will remove the entire exhaust system and bolt it back on, if that doesn't work then they'll probably go thru the replacing route, i hope. i was gonna ask them to file for a replacement right away but they said they have to give it a try before notify Acura for the replacement.
brought my car in this morning and they called me same day afternoon said they fixed the problem. went to pick up my car, looked like the two exhaust outlets are evenly aligned now. but when i read the detailed paperwork when i got back home(should've read while i was at the dealer), it said the measurement now for both sides are 1.25 inches(from the bottom of the bumper i guess), whereas before the driver side was 0.75 in and passenger side was 1.25 in. i thought they supposed to use the higher side as the target so that both should be measured at 0.75 inch after the re-alignment. from naked eyes, it looks like the dealership has done a fantastic job, just the final measurements on paper puzzled me a bit, instead adjusting both outlets to 0.75 inch, i'm afraid they hung both outlets too low, but like i said it sure doesn't appear that way by looking at it.
Yea, It's Me!
Stand about 10 yards behind the car and look at the whole car, not honing in on the tips. The pipes should be pretty close to being centered in the cut out. It shouldn't be too close to the top so the system can bounce over bumps without banging the bumper. Sounds like they did the job. Enjoy!
Yea, It's Me!
Re-read this post. Kev's came out to his satisfaction. You won't know until you try to get it resolved. If it bothers you now it will continue to bother you. Get it fixed.
Edit: Now that I think about it, When I looked at the back of our TL the other day I thought one of our tips was off, but I had been drinking heavily that day...well everyday.
my passenger side exhaust pipe is about a 1/4" lower then the drivers side...it was really hard to see, but when i stuck 2 fingers inbetween the center of the exhaust tip and the bumper cut out, you can see there is a difference...
its not enough for me to take it to the dealer, its just not really noticable unless your are a complete o/c ahole like me...
ExcelerateRep
Sponsored Sales & Group Buys
01-06-2016 09:59 AM
ExcelerateRep
12-11-2015 12:58 PM
IIDXholic
10-08-2015 07:53 AM
