Need help fast
Old Mar 20, 2012 | 05:07 PM
07TLFIXITUP's Avatar
2012 TL Tech
Exclamation Need help fast
Im currently wiring up resistors on a 12 TL and can't stop hyper-flashing. I'm pretty damn sure I'm on the correct wire but I've tried four different ways and no luck. I was told by the seller of the resistors that one end goes to the turn signal, and the other end of the resistor goes to a ground. I wired it this way with negative results. I then wired both ends to the turn signal line and had negative results. Next I put a resistor on the front line and left the back line still wired as a bypass and tried the front line both with a ground AND as a bypass... Both with negative results. I even put the factory bulb back in the front and tried and still had hyper-flashing. Either this isn't going to wor, I've don't it wrong or I'm tapping the wrong wire... Thing is, on the rear turn signals, there are only 2 wires going to the signal ; a color wire(L-Blue R- green) and the second wire on both sides is solid black.. PLEASE SOMEBODY HELP
Old Mar 20, 2012 | 05:54 PM
2012 TL Tech
Problem solved.. For anyone with this task in the future. The other end of the load resistor MUST tap into the ground wire running to the signal . NOT just any ground.
Please close thread...
Old Mar 20, 2012 | 06:19 PM
potmilkz's Avatar
when they say ground.. you dont necessarily bolt it to the frame.. its the wire..
Old Mar 21, 2012 | 09:31 AM
lji's Avatar
lji
There may be a difference between signal ground and earth ground in your case...
jterp7
3G MDX (2014-2020)
Feb 3, 2016 08:34 PM
Frathora
Sep 28, 2015 11:29 PM
Froid
Sep 27, 2015 06:16 PM
