My SH-AWD system turn off and ABS..
Hi I got a 10 acura tl SH . this morring I turn on my engine and the light indecater on , on my dashboard .one for check SH systems and one for airbag system , I have Takeda/j-pipe/tein basic/black out lights front and back on my car I call the dealer to make appointment on this monday comein up, do they VOID YOUR WARRANTY if you have that done to your TL ? Or how can I fix that problem? Your help will be preciate.....
Start checking fuses. Have you pulled your battery yet to reset ECU? Make sure you have nav code first...
Any recent work to the car? Maybe a sensor connector popped loose.
Any modification to the car gives them an excuse to blame it on you and not honor the warranty. Technically, if they can't prove it, then you're stuck arguing with them, without a car or a car in good order anyway, while you sort it out.
Check all connections and fuses; code reader is a god send.
Is it Check SH-AWD and Airbags or Check SHAWD and ABS system?
If it's ABS and not airbag, then it's a wheel speed sensor that is the problem and acura can't blame any of your modifications. Acura can ONLY void your warranty IF the aftermarket part causes the problem.
Like you put on the takeda intake, if a month later the power seat breaks the dealer can't blame the intake since it has no connection to the power seat.
It's called the Magnuson Act:
http://en.wikipedia.org/wiki/Magnuso...s_Warranty_Act
Lef76oast (07-24-2011)
rockyboy
08-04-2024 10:35 AM
mada51589
05-03-2022 08:54 PM
ostrich
09-11-2015 04:28 PM
