Must insert keyless into slot to start
I have a 2011 TL TECH that is only 2 months old. The other day when I exited the car and pressed the door handle lock it did not lock. had to use the Fob to lock.
When I came back to the car after placing my hand on the dorr handle it would no unlock.
upon entering the car, it insisted I insert the fob in order to start and has ever since. Fob 2 which has only been used once also does the same thing...
Any ideas? My dealer over the phone did not have a quick solution.
R.
R.
Check the switch inside the glovebox. Make sure the keyless option is set "ON"
Ant$ (12-29-2011)
If the suggestion above does not work, your fobs may need new batteries (although that seems unlikely).
rockyboy
12-06-2022 02:29 PM
tman570
06-11-2019 07:56 AM
