Mild grinding shift
Old Oct 13, 2017 | 08:47 PM
Raymond Sanchez's Avatar
Mild grinding shift
Before taking car in and spending thousands of dollars I am hoping I can get some advice on what could be the problem. I hear a mild grinding sound when shifting in low gears at a low low speed. Not every time but is noticeable. I pray its not the transmission going out. 92k miles on it. Thanks in advance!
Old Oct 13, 2017 | 09:05 PM
horseshoez's Avatar
Latent car nut
Pretty simple fix, replace your MTF with ACDelco Synchromesh Friction Modified. Note, there are two ACDelco Synchromesh formulas, make absolutely sure you buy the Friction Modified stuff.
Old Oct 13, 2017 | 09:29 PM
MTF vs ATF? On automatic...because if thickness?
Old Oct 13, 2017 | 11:48 PM
meowmeows's Avatar
The linked Manual Transmission Fluid should only be used for manual cars. It works beautifully though.
Old Oct 14, 2017 | 06:19 AM
horseshoez's Avatar
Latent car nut
When you talk of mild grinding while shifting gears I assumed you were talking about a car with a manual transmission; if you have an automatic then disregard everything I said.
Old Oct 14, 2017 | 10:33 AM
That was my fault. I thought of that as soon I posted it...Thanks again!
Old Oct 28, 2017 | 09:19 AM
SkN012's Avatar
Im due for a MT fluid change. How many of the 32oz bottles will I need?
Old Oct 28, 2017 | 12:13 PM
horseshoez's Avatar
Latent car nut
Three, the manual transmission takes 2-quarts, 10-ounces.
