Large leak from front driver side
Old 11-21-2014 | 06:16 PM
01clsstock's Avatar
i am so smart S M R T
Question Large leak from front driver side
okay so I just left work and noticed a puddle when I pulled away. Didn't think much of it until I got home and some fan or something kept running for 2 minutes when I got out of the car. Looked down and noticed what looked like oil and water leaking out..... how bad is this?
Old 11-21-2014 | 06:30 PM
rockstar143's Avatar
Oil AND water?
No, it's gotta be one. If I had to guess...it's your radiator hose and that's just dirty coolant. That would explain the fan running to bring temps down.
Good luck...
Easy and cheap fix too, if that's all it is.
Old 11-21-2014 | 06:33 PM
01clsstock's Avatar
Oil AND water?
Good luck...
yeah upon further exam no oil, but it looked bluish in color.
Old 11-21-2014 | 06:42 PM
1) blue is the color of OEM coolant.
2) find out where it's gushing from.
Old 11-22-2014 | 08:11 AM
01clsstock's Avatar
Thumbs down
couldnt tell where it was coming from so i am going to have it towed to the dealer.
Old 11-22-2014 | 08:15 AM
That's more of an indictation that it's the hose...it bust under pressure...once it cooled down the rip wouldn't be that obvious. Inspect your radiator hoses closely...change them both for good measure. If it was a gaping hole in the radiator it'd likely show when the car was cold.
Buy a thermostat (might be bad and have built the pressure that busted the hose in the first place)...both hoses...and a gallon or 2 of the Honda type 2 coolant and go to work. It shouldn't take you more than a couple hours.
You're welcome.
Old 11-22-2014 | 10:30 AM
Tonyware's Avatar
'20 TLX SH-AWD A-Spec
The coolant is blue. Once dried it leaves a green-ish color stain. If you look in the engine bay and see any of these green stains you can easily tell where the leak is coming from, probably directly above the stain.
Worse case scenario you hit something and the radiator is punctured. Kinda scary to drive a car that can potentially overheat... taking out head gaskets etc.
echodigital (11-23-2014)
Old 11-22-2014 | 02:10 PM
01clsstock's Avatar
Exclamation
Well acura just called me and said my radiator had a leak and that it would cost $764.00 to fix.....
Old 11-23-2014 | 08:25 AM
echodigital's Avatar
Keeping TL until 2029
Ugh...sorry.
This was an informative post.
Old 11-23-2014 | 08:32 AM
If you're handy, that could cost you much less to install yourself.
Old 11-23-2014 | 08:44 AM
the OEM radiator cost $100 dollars from Rockauto.com
its the Denso Radiator
next; replacing the radiator is an hour job at most.
its the simplest easiest thing to do, even for a noob.
its literally a plug and play job.
Cant get it wrong.
remove hoses.
remove fan clips/harnesses.
remove clips/bolts that are holding down radiator on top.
remove radiator.
remove fans from radiator.
replace fans onto new radiator.
install new radiator.
clip up fans harnesses.
hook up hoses.
bolt down radiator
Old 11-23-2014 | 03:20 PM
Tonyware's Avatar
... do the refill procedure with the cap loose to get the bubbles out and a towel wrapped around the neck of the radiator while the engine heats up to over 90oC to get the fans going. Also after you throw in the new radiator, take a piece of cardboard and place is in front of it before you attempt to re-install the fans. Yep, it can be an expensive weekend if you mess that up - lol, speaking of past experiences.
PS if you take to the dealer, inquire where did the radiator leak from? Was it defective or did the pipes puncture somehow. Inquiring minds need to know to see what else we, the rest of the 4G TL people here, should expect to happen in the future...
justnspace (11-24-2014)
Old 11-26-2014 | 06:12 PM
Justin...kudos for trying...but don't even bother.
Old 11-29-2014 | 10:18 AM
01clsstock's Avatar
They said the leak was in the lower resevior and probably caused by a rock hitting it or something to that extent..
echodigital (11-29-2014)
Old 12-02-2014 | 10:41 AM
Cool. You're welcome.
csmeance
09-10-2018 10:15 AM
nanos
11-12-2015 09:41 PM
Ny1718
09-11-2015 10:21 AM
JnC
09-11-2015 07:06 AM
08 NBP TL
09-08-2015 09:49 PM
Quick Reply: Large leak from front driver side
