How do I change this fuse type?
Old Oct 24, 2014 | 04:59 PM
The Professor's Avatar
It's my first time trying to change this type of fuse and I'm not sure how to proceed.
Look at the attached picture from the TL manual. I pulled this exact fuse group, it's from a 2012 TL (under the hood fuses) and I want to pull the fuse 2-5 so that my headlight washers won't work (Canadian model).
These fuses all seem to be connected, I didn't know how to separate them to remove the one I don't need without breaking something.
Can you help??? How do I do this? Pics would be great.
Thanks, AL.
Old Oct 24, 2014 | 08:54 PM
Edward'TLS's Avatar
6G TLX-S
The "connected fuses" you refer to is called "multi-block fuse".
It is actually one single fuse block, and the enclosed fuses cannot be separated or pulled, without damaging it.
Old Oct 25, 2014 | 08:45 AM
Thanks Edward'TLS, I was not familiar with these fuses. I'm glad I asked before trying to separate them.
Now I'll have to figure out another way to stop the headlight washer from automatically activating.
Old Oct 25, 2014 | 09:00 AM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
Here is another post on this topic. https://acurazine.com/forums/audio-b...washer-874525/
One poster in this thread suggested pulling a 30A fuse???
Old Oct 26, 2014 | 03:05 PM
Yeah I tried to pull these fuse but I couldn't (see me original post) I wish it would have worked as it would have been an easy fix.
Old Oct 27, 2021 | 05:17 PM
WDPanda's Avatar
I ran into this fuse type problem as well.
How did some of you just pull this multi fuse?
i'm leaning towards disconnecting the headlight washer pump.
Old Oct 28, 2021 | 03:10 AM
WDPanda's Avatar
I ended up disconnecting the pump, no issues so far.
There is a separate pump for the windshield washer towards the firewall and the headlight washer pump is closest to the front bumper, same as you'd change a passenger side fog light bulb (1 bolt and 1 fender clip from the bottom).
Took about 5 minutes.
desibaba
Jan 8, 2023 03:03 PM
StormTrooperTL508
May 13, 2014 09:59 AM
zajac66
1G RDX Problems & Fixes
Feb 23, 2011 09:21 PM
eric25332
May 14, 2010 04:27 PM
PixelHarmony
Nov 11, 2006 12:51 AM
