High Pitched Noise from Fuel Tank
Old May 16, 2016 | 07:36 AM
mossman77's Avatar
I currently have my back seat out in order to Dynamat the rear deck and noticed a high pitch noise coming from the driver's side of the fuel tank. I believe the driver's side contains the filter and the passenger's side contains the pump. Is this correct? Is this noise normal? If so, I guess I'll try to supress the noise as much as possible by dynamatting the sheet metal above the tank/under the seat. Although I didn't notice the noise with the seat cushion in place so it's probably okay as is, but I figured why not dynamat it anyway.
Old May 18, 2016 | 06:34 AM
wreak's Avatar
Did you start the car when you heard this noise? Yet the pump makes a high pitched noise and it's normal.
Old May 18, 2016 | 09:07 AM
mossman77's Avatar
Yes, the noise only occurs when the car is running. I assumed it was normal. I'll likely dynamat and may even put some sound deadening material underneath the seat. Probably overkill though.
00TL-P3.2
Feb 11, 2019 11:23 AM
Elliotak
Mar 5, 2016 12:35 PM
Mugenx
1G TL Problems & Fixes
Jan 10, 2016 10:26 PM
