HID Ignition problems
Old Nov 23, 2009 | 07:02 PM
BLACKURA_NY's Avatar
I have car ADD
My Passenger side HID headlight is giving me problems, and i just wanted to get some feedback...
I feel like a noobie asking this, but when i turn on the headlights, the bulb wont ignite... i have to turn the headlights Off & On like 2-3 times until it finally ignites...
Should i focus on the bulbs? Or does this seem like a Ballast problem? I have Kaixen 6000K D2S bulbs in there, so I want to take this into my own hands, before I go to the dealership
Old Nov 23, 2009 | 09:48 PM
benzboy429's Avatar
did you use a relay when installing? I know cars with auto on/off headlights like ours we require a relay. Also from past experience with my other car and HID's I had loose wiring. I had to remove the electrical tape and fasten and then re apply.
Old Nov 23, 2009 | 10:03 PM
I have car ADD
See... if these were an aftermarket HID system, first thing i would check is the relay...
but do our OEM headlights use a relay of some sort? would the relay be in the fuse box under the hood?
Old Nov 24, 2009 | 09:26 AM
free598's Avatar
Im Broke But Im Ok
did u put the OEM bulb back in an try it
Old Nov 24, 2009 | 09:56 AM
bagbklyn's Avatar
If you only change the OEM bulbs I guess it would most likely be the bulbs. I haven't seen anyone on the forums complain about the bulbs being an issue. Now if it didn't turn on at all then I would say check the ballast or the relay. But first like he said if you can try the OEM bulbs to see if they work.
SidhuSaaB
May 30, 2020 12:40 AM
LoneRonin
Jan 4, 2016 01:03 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
