Grinding from center console while accelerating and turning
Old Sep 14, 2013 | 03:31 PM
calidad03's Avatar
hey guys,
i have a 09 tl tech.
i have had this issue for 4 months now and have been to acura 10 times and told the problem was fixed and still has not been.
while turning i get a grind noise from the center console/ dash board. it happens more when ac is on high. also is worst on u turns. at first i thought it could be things inside my compartmenst and took everyting out same thing.
acura has repalced peices here and there in process damaging other things, but the issue still persist.
its sounds similiar to alot of people complaits on here however its not any creaks from bumps in the road its a steady grind until i straighten the wheel after the turn and it stops.
please help
Old Sep 15, 2013 | 07:01 AM
echodigital's Avatar
From TL to RDX
If you still have warranty, take it to the dealer. Some else needs to be looked at. If this is repeatable, take it out with the lead mechanic in passenger seat. I had my propellor shaft replaced and I had mechanic sit in car for a drive (i.e. to demo whistling noise).
Old Sep 5, 2014 | 11:25 AM
rcannon440's Avatar
I have the same problem with a grinding noise only when I turn the car left or right while giving the car gas from a stand still. Did you resolve your grinding issue?
Old Sep 9, 2014 | 08:41 AM
CerberusKy's Avatar
Check your CV boots to make sure they are not ripped and have lost there grease.
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
bymotion
Nov 18, 2015 11:28 AM
PortlandRL
Sep 14, 2015 12:01 PM
