Ghost in the Machine, Please help, Presets Cancel themselves
Hello All
I have had my 2011 TL for about a week, and in that time i have subscribed to XM and set my presets
I have also got my seat and mirrors where i want and stored these preferences in "seat memory #1" on the door
this morning i attempted to get in the car but the seat was too far forward, i moved it back and got in, started and began driving
my second indication of a problem was that the mirrors were moved, i put it in park and pushed seat-1 on the door, the seat and mirrors promptly went to their set location...... but all the radio presets are gone, the sync button was lit so i turned it off and still no luck, the radio presets seem to be permanently gone
before you say "read the manual" i skimmed it and was unable to find anything about an "overnight deletion of presets" feature which activates weekly
did the car reset to some factory default mode?..... i did not change the battery, or lift hood.... just parked it overnight
any help would be greatly appreciated
cheers
John in Fargo
cheers
John in Fargo
there was a momentarily loss of power, which reset all of your settings.
sometimes, the battery will corrode the battery terminals and associated wires. Check them to see if they are tight and corrosion free!
OK so I called the Acura Dealer, the service rep asked me if i switched key fobs....... i had not but apparently switching fobs would cause this as presets are tied to the fobs
the girlfriend confessed to having put the other fob in her purse in case she "needs" to drive my car...... she walks between both of our cars to get into her car
the guy at Acura says her purses close proximity to my door as she walked by unlocked the car with her fob just before i got in and drove
I tested this theory and walked out to my car just now and got in, started it and all my presets are there
I have since confiscated the 2nd fob to prevent this from occurring again, and to reduce the likelihood that she will drive my car
Funny story but something doesn't sound right. If you get in the car with your remote the presets should be as you set them for that remote regardless if the other remote was used (or passed by) before.
Do you trust her with the family jewels?
Well, yes i trust her with the "jewels" as you put it.... but my concern with her using my car is that she will put country music on my radio and possibly even preset them...... I just can't allow that to happen
You shouldn't have to reprogram your presets if your programed your seat settings via the button by the door handle.
Press the bottom button and then button 1 or 2 that corresponds with the remote.
It should save your seat position, side-view mirror positions, and radio presets.
