Fluctuating Alternator Voltage
Old Aug 26, 2016 | 07:35 PM
mossman77's Avatar
I've been monitoring some engine parameters using a real time OBDII scanner and one of the things I'm monitoring is the control module voltage. Curiously, the voltage varies between 13.9V and 12.3V. For example, I was sitting at a red light and it was 12.3V, then I turned on the headlights and it increased to 13.9V, then dropped again while driving. So bizarre.
Old Sep 2, 2016 | 05:18 PM
Reorge's Avatar
This is normal per my understand of our electrical system. Our system is designed with a two stage voltage regulator (two voltage values). It determines which voltage is needed for best performance and best efficiency. One scenario is when the battery is fully charged a lower voltage output is satisfactory. I try to find the document that explains this.
Old Sep 2, 2016 | 05:44 PM
Reorge's Avatar
Scroll down to BATTERY MANAGEMENT SYSTEM (BMS)
2012 Acura TL - Powertrain - Honda.com
Old Sep 12, 2016 | 09:23 AM
mossman77's Avatar
Thanks for that. Glad to hear it's normal.
