Creaking Dissapointments
As the weather starts getting warmer... the 4G TL I bought last month started producing very noticeable rattling, creaking and squeaking noises everywhere like a rickety rickshaw: in the A pillars, B pillars, sunroof area and near the rear speakers. I also start hearing "pops" that sound like a cicada. Honestly, what is the deal with this?! Is this not a $45k car? It still only has 22,500 miles on it.
I am very annoyed, depressed and disappointed at Acura. I've done the forum search and this appears to be a very common issue with multiple TSBs issued. I've driven $10k Hyundais that drive just fine in 100 degree weather... why is this happening to my top of the line Acura?? Here's to hoping my visit to the dealership on Friday will fix anything. Are these issues repairable? Anyone else with OCD like me that found resolution? Please give me hope! |
As you already mentioned a lot of these problems are known and fixable. The creaking you might be hearing in the back I believe is from a styrofoam piece inside the door thats for sound deadening but is prone to coming lose. I would post all the TBA's relating to the problems you're experiencing and print them out to bring to your appointment. Also make sure you remove everything from the car that might be causing these problems: sunglasses in the the holder, loose change, tools in the glove box, thing in the door compartment holders, etc.
Originally Posted by mynameisjacob
(Post 14455879)
You are not the only one. I'm too extremely disappointed. I bought a brand new TL last May, and just a few days later when temps heated up squeaking noises started to come up from all over. The most annoying was rattling from inside of the passenger door. Took it back to the dealer, they squeezed some foam inserts here and there, but it didn't help much.
I was expecting a lot more from a 45k car, and the Acura brand that claims to be luxury. Huge disappointment. |
Originally Posted by Acura_fan12
(Post 14456023)
I'm noticing some of those symptoms but then they go away and then they come back. IDK, maybe I'm just nitpicking because I got it brand new. I do have some loose items in my car though and that won't help with the noise LOL.
Funny, the only noise I hear in my 2009 is the change rattling around in the center console.
Originally Posted by Mr Marco
(Post 14456332)
Originally Posted by HeartTLs
(Post 14456400)
My 09' was very solid too. I thought a rear window was rattling at one point and then figured out it was roof spoiler that had come loose :tomato:. My 12' Has also been rattle free, I'll try and listen to see if warm weather affects it.
Originally Posted by Booya4139
(Post 14456732)
Yep, my 09 has been great...only rattle is from my sunglass holder, I need to add some foam or cushiony material in there to quiet it down...
same rattles here. My are in b pillars, and headliner. Most annoying is the b pillar where the seat belts go in right by my ear. It's driving me nuts, I bought shit load of dynamat will be doing all doors, pillars, and if I figure out how to remove the headliner.
My 2006 Jetta is solid compared the 2012 acura tl, not as fast, but rattle free. Jetta is on stiffer lower suspension and that did not introduce any new rattles so not sure if the SH-AWD has anything to do with it. |
(Post 14456332)
Some of what you may be hearing is the doors and sunroof moving around a bit on the seals/gaskets. After the winter the seals are dirty and dry and don't mate up against the sealing surfaces quite as well. Try buying some Shin-Etsu grease from a Honda dealer. (It's expensive, but almost magic). Clean the seals and sealing surfaces and then apply the grease per the instructions. Our old Accord had a sunroof/headliner noise that drove me crazy in warm weather almost from the time we first got it. I applied a little Shin-Etsu to the sunroof seal because it looked like it was drying out, and the noise instantly went away never to return.
Hmmm maybe I will! Dynamat everything!
On a scale of 1 to 10... how difficult is it to remove trim pieces and side panels and such? I've never done it before on any car. Do I need special tools? Does it cause damage to the actual panels if removed wrong? |
I am noticing many of the same issues on my 09 as well. The sunroof most recently has been ratttling whenever i go over a bump or close the door.:whyme:
my 2013 tl sh-awd 6-speed with 3,500 miles on it already has an annoying squeeking sound coming somewhere from the back
Hey Piotr... I know you... its me Jacob... from Syska. We met during the columbia walkthrough. Funny seeing you here...
Originally Posted by JM2010 SH-AWD
(Post 14457379)
all i hear in mine is my progressive sway bar + tein coils creaking when i go over speed bumps.
I had a creaking sound coming from the rear. It was because the bottom of my back seat wasn't all the way clipped in. If it's not completely secure the leather will rub when the car flexes over speed bumps etc. There are 2 clips in the front of the rear seat that hold it together.
(Post 14455879)
(Post 14455956)
Wonder how HMCo can produce two cars off the same line that have two totally different outcomes? However, my TL was a press demonstrator, sooo it may have been given the fine tooth comb treatment before anyone actually drove it/ |
(Post 14515586)
I don't have any of these issues.
(Post 14515267)
Did you have to clean the areas you were going to grease before applying the Shin-Etsu? My sunroof when fully retracted with the covered pulled back makes creaking noises that drive me crazy. I'm planning on taking care of it ASAP.
My rattles come from the door panels and sometimes from the sun roof. The dealership fixed one door panel and missed on the other. The response on the sun roof was that they could not locate it. Bullshit answer if you ask me when you drop 44k on a luxury vehicle
Originally Posted by dvdpgb
(Post 14518769)
You have a valid complaint if your Acura rattles and squeaks.
Mine does too. (2010, FWD) The steering wheel buttons and cover pad etc. squeak. I think I have the dreaded moonroof rattle since it seems to go away when I close the cover. The armrest squeaks when I lean on it. I try to drown out the rattles by turning up the stereo but the door speaker is blown. Catch-22. I do love the looks and the engine though. |
My wife's Camry is 11 years old with 200,000 km on it and it doesn't have any of these rattles. Boring car but it runs like a watch and it's quiet.
Originally Posted by jim_c
(Post 14543880)
Mine does too. (2010, FWD) The steering wheel buttons and cover pad etc. squeak. I think I have the dreaded moonroof rattle since it seems to go away when I close the cover. The armrest squeaks when I lean on it. I try to drown out the rattles by turning up the stereo but the door speaker is blown. Catch-22. I do love the looks and the engine though. Jim, I think I can help you out with some of the issues. 1. moonroof rattle - Put your fingers into the gap between headliner and moonroof opening at its midpoint and pull down slightly. It will detach the velcro that attaches headliner to the frame. When I did this, it got rid of the moonroof rattle. YMMV. 2. Armrest squeaks - (I'm assuming you're referring to the center storage console armrest) Put vaseline jelly on the rubber stopper that goes into the latch. BOOM, no more squeak. |
Originally Posted by potmilkz
(Post 14515334)
