Courtesy door lights not turning on
Hey everyone!
Ever since I bought my 2012 I don't think I've ever seen the courtesy lights come on for both the driver and passenger door, is there a setting or something to turn them on? Do the lights need to be set on automatic for them to work?
Should I look at getting a new set of bulbs?
Thanks!!
Thanks!!
Yea automatic. If off they will be off
Also make sure if they are aftermarket LED bulbs that they aren't burnt out or installed backward. Did you buy it new or used
Thanks for the info!
Then polarity shouldn't be an issue. If all the lights are out including dome, your interior lights fuse might be blown too..
That's the thing, all the lights work perfect, dome and everything, I usually leave my light setting to off until I need them when it starts getting dark, I'll try auto and see if it changes anything
If you have a multimeter, pull the bulb and carefully put the test prongs on each lead to make sure the door is getting power. Or check the bulb, probable they both out but not impossible ..
Hey everyone!
Thanks!!
Thanks!!
Some people try to use Led logo courtesy lights and those can cause the MICU to burn,if that is the case then you are out of luck. You will need to rewire them from another source or change the MICU.
rockyboy
08-04-2024 10:35 AM
drewdeezy03
09-03-2015 08:04 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
