View Poll Results: Does your TL have corrosion on the aluminum engine subframe and rear knuckles?
I don't know and I don't care...
55.56%
I don't know, but now I am worried and will check...
33.33%
No, I have checked and the parts are fine.
11.11%
Yes, I have checked and there is enough corrsosion to be a concern!
0%
Multiple Choice Poll. Voters: 9. You may not vote on this poll
Corrosion on aluminum subframe and rear knuckles due to road deicers?
Hi:
I just acquired a 2010 TL SH-AWD 6M and I am a little concerned about the aluminum chassis components. The Washington State DOT and my city both use sodium and/ or magnesium chloride on the streets as a deicer. This stuff is deadly on unprotected aluminum. Can anyone tell me:
Have you seen corrosion on your aluminum chassis parts? If so..../ how bad is it? Where do you live and what sort of road chemicals are used there in the winter? How often do you wash the underside of your car?
Does anyone know what surface treatment Acura uses on these parts, such as clear "hard anodizing"? http://www.superiormetals.us/hardcoat-anodizing.htm
Can someone recommend a good aftermarket solution that I can apply myself, such as Boeshield T-9? I have used this in the past with success, and I think a good cleaning and coating with T-9 in the Fall would provide decent protection. http://boeshield.com/
Thanks for any and all comments.
BTW: how do you post a poll here?
John Davies
Spokane WA USA
John Davies
Spokane WA USA
OK, I figured out the Poll, now I can't edit my first post - what's with that?
BTW: I made it possible for folks to vote more than once, so you can report back if you inspected and found corrosion, or not.
John Davies
Spokane WA USA
John Davies
Spokane WA USA
Are they using salt on the roads or that chemical w/sodium like we use in Portland, OR?
in toronto, canada, we use salt, and a brine solution of some sorts, as a preventative spray before the snow comes down or before it goes below freezing temps.
i know out west in canada they use sand instead.
rockyboy
08-04-2024 10:35 AM
asahrts
09-04-2015 05:55 PM
