coldest temp for acura tl 2012
Anyone having an issue with the temperature for acura tl 2012? Does the temperature not get below 45 degrees. My Freon level is in the green zone, but its not getting below 45 degrees. The outside temperature is at 67 degrees. Is this normal for this model TL or it can get colder around 35-40 degrees. Thanks
Welcome to the forums.
The following is posted at the top of the New Member Introductions Forum: Welcome! Please introduce yourselves here, BUT ASK FOR HELP IN THE TECHNICAL FORUMS
Since this is a topic/technical issue which will require replies and discussion, this thread has been moved from the New Member Introductions Forum to the model specific forum for better response.
