Check SH-AWD, ABS, VSC lights went on
Okay, I turned on my car today and all 3 lights came on for check SH-AWD, ABS, VSC. Last night in NYC there was a pretty bad storm and went through one or two puddle. I'm thinking it's because of that. Anyone know how I can fix this or if anyone else had similar problems?
1st start up: Check SH-AWD, ABS, and VSC lights went on. Car wouldn't shut off for 15 minutes. Placed into park, press the stop button, stop button kept flashing on and off. Eventually, I kept trying and it just turned off.
2nd start up: Few minutes later, started up again to see if that's the case. Only the ABS and VSC turned on.
Any ideas?
Car is 09 TL SH-AWD
Any ideas?
Car is 09 TL SH-AWD
I turned on, drove it around and turned it off again 2 more times. The lights just went away. Tried turning it on and off a few more times and the lights never showed. Anyone know what just happened? I'm still going to take it to the dealership to make sure everything is alright
all three of those lights have to do with wheels and brakes.
there are sensors on each corner.
maybe the storm you went through upset a few of those sensors.
you can check to see if any sensors are damaged or unclipped but it sounds like the problem fixed itself.
If you can still brake, then I wouldnt worry about it unless it happens a second time.
went to the dealership did a diagnostic, and concluded that there were no issues. i brought it back home and few days later, same thing happens. all three lights. i wanted to verify that it wasn't BS so i found a secluded area and gassed it. There were so much tire squeal and wheel spin that i concluded the lights are real. not sure what steps to take next. what can i check myself?
Basically, all three will light up if it detects a problem in the brake circuitry. I call it the Trifecta warning.
Also, did you see my post about using aftermarket lights? Even if they are stock, could also try unplugging one of the brake lights to see if you can duplicate the problem. Do you notice if the problem occurs only when the parking or auto lights are on? Use a stick to hold down the brake pedal and go check to make sure they are both working, and at the same brightness.
https://acurazine.com/forums/showthr...1#post14001212
A TSB does exist for faulty brake light switches. (1 possibility)
![Check SH-AWD, ABS, VSC lights went on-gnzqs.jpg](https://acurazine.com/forums/attachments/4g-tl-problems-fixes-297/113853d1683168532t-check-sh-awd-abs-vsc-lights-went-gnzqs.jpg)
Looks like the battery is ok. That would have been a nice simple fix. I hope you get it sorted out.
just reporting back i got the issue resolved. its been 2 days and approximately 50 miles and the lights haven't come up. the acura of brooklyn has replaced my left rear speed sensor!
mada51589
05-03-2022 08:54 PM
HeloDown
09-08-2015 06:51 PM
