Car pulls when braking?
I've noticed on multiple occasions when I brake the TL to a complete stop, the car sometimes (not always) pulls to either the left of right. I have to compensate for the directional pull via steering (to avoid hitting a car next to me).
Of course, the dealership cannot replicate the problem, so they cannot fix said issue.
Any ideas what may causing the pull? Uneven brake linings? Contaminated brake fluid? Premature wearing of break pad?
I have ~14,000 miles on my TL.
It should not be doing that at all with only 14,000 miles. Sounds like it could be the front end alignment. Do you remember if you hit a bad bump or a curb. It does'nt take much.
The symptoms of a car that is out of alignment are:
- Uneven or rapid tire wear
- Pulling or drifting away from a straight line
- Wandering on a straight level road
- Spokes of the steering wheel off to one side while on a straight and level road.
If it was an alignment issue, it would be a repeatable issue. I'm sure its something to do with the crown of the road. I mean if you yourself can't replicate the issue on a regular basis, how's the dealer supposed to. And it varies from left to right? very difficult to pinpoint.
i have a similar issue like this and recently just got my alignment done, and new tires. still happens on and off. the only thing i have noticed is that it happens on the same stretches of road so i am almost sure it has to do with the crown in the road
Thanks for the responses!
nuldabz
09-03-2015 05:49 PM
