car jerks and engines stalls from a stop
Old Oct 21, 2022 | 10:32 AM
Devasta00's Avatar
My car has about 81k and been doing regular maintenance accordingly to the manual ever since I bought it used with 62k on it. Recently the car would jerk as soon I accelerate from a stop and the rpm would drop. I drove it for about 20-30mph than the engine just shuts off so I took it the repair shop and was told that the ecu module needed to be replaced. My question is what would cause it to fail and is this a common problem with 2010 tl base models? I had owned 8 different cars new and used with almost 90k on it and none have had this issue.
Old Oct 21, 2022 | 07:45 PM
altair47's Avatar
Have you tried relearn the throttle body? With such a service, burn the ECU only if you reverse the polarity when connecting the battery, But then the car probably wouldn't start.
Old Oct 24, 2022 | 08:40 PM
Devasta00's Avatar
the repair shop told me was the ecu module and they can't even program it after they replaced the original
Old Oct 24, 2022 | 09:16 PM
altair47's Avatar
This is not a common problem, so it's either a misdiagnosis, or the repair shop really burned your ECU. If shop burned your ECU, then he should be responsible for it. If shop do not have Autel to write down the VIN to the ECU, you need the KEY, FOB, ECU, LOCK CYLINDER, AND STEERING LOCK SET, or go to the dealer so that he write down your VIN to the new ECU.
Teddybear
4G TL Problems & Fixes
Mar 14, 2020 06:01 PM
KimcheeJ37
Sep 4, 2019 09:46 AM
booster
Mar 7, 2017 07:38 AM
real_mckoy
Jun 24, 2014 05:51 PM
metalblaze
Oct 13, 2008 09:34 AM
