A/C is not blowing cold on driver side
Old Jun 19, 2021 | 07:57 PM
ramosrayrobert's Avatar
I have a 2011 Acura TL. The Ac is not blowing cold air on drivers side but does to feet, passenger, and back. Anyone else have this problem?
Old Jun 19, 2021 | 07:59 PM
it's the "Blend door" or the actuator. it's likely stuck in one position.
you're lucky...my driver side is stuck too, however, it's stuck in the position to where it doesnt blow heat...not so much an issue in the summer. but in the winter it blows ice cold. LOL
you can do either one of two things....remove the actuator, open it up and clean the contacts. or replace the unit entirely.
Old Jun 20, 2021 | 10:35 AM
Ron A's Avatar
Administrator
Welcome to the forums.
Since this is a topic/technical issue which will require replies and discussion, this thread has been moved from the New Member Introductions forum to the model specific forum for better response.
Old Jun 20, 2021 | 07:55 PM
Reorge's Avatar
My son had a similar problem in his 2004 Accord (same dual auto-temp HVAC as our TLs).
I checked the blend doors and they worked properly.
Turns out it was low on Freon. Many Accord forum participants had similar issues and resolutions.
Old Jun 22, 2021 | 09:00 PM
WDPanda's Avatar
If it's only the AC causing this issue, it can be from low freon.
Steelman512
1G CL Problems & Fixes
Jun 19, 2015 03:05 PM
acurasienz
Apr 4, 2013 06:12 PM
joelmatt89
May 3, 2012 07:17 AM
phishfood
Aug 28, 2011 05:58 PM
Narbin
1G TSX Problems & Fixes
Aug 4, 2010 10:05 AM
