Bearing for my climate control fan went out?
Hey all,
Just started getting this noise driving a bit earlier this morning. Seems like the bearing for the fan is giving out. I took out the air filter and felt around the fan, but it wasn't wobbly and there wasn't any debris there or anything that I could see. Is the fan easy to replace? I know it's a pretty cheap part (sub 100 dollars) but it looks like it might be kinda difficult to remove everything and work on it. Any ideas?
https://photos.app.goo.gl/xmPeGFqYa8tt5qdKA
Is my diagnosis correct?
Sounds like the fan to me. But I haven't had mine go out so I can't say for sure. However, I can't imagine what else would start making a noise like that once you start up the fan.
Here's the instructions for removal and replacement:
You could go OEM but for something like a blower motor, aftermarket is probably just fine. RockAuto has them starting at $37.
https://www.rockauto.com/en/catalog/...wer+motor,6916
The noise stopped! I don't understand why or how but All day yesterday I was on high heat, high fan when stuck in the snow for like 2hrs and not a single bit of grinding noise at all... Hmm.
Sometimes you can get dirt or debris stuck in the fan and it can create some nasty sounds.
Not highjacking thread.. 🤪
To piggyback on your issues my issue is that A/C blows fine through passenger vents, both front floor vents but blowing only slightly through passenger air vents and rear.. I checked the cabin air filter and it’s fine.. is there a separate fan for passenger upper vent and rear?? I’m stumped.. TIA
Gunny Highway
07-13-2008 03:08 PM
cd5-obsession
07-12-2008 10:54 PM
hdp203
07-25-2007 08:03 PM
