2013 TL Torque Converter Issues?
Old Nov 26, 2014 | 04:47 PM
Jaco's Avatar
Hi all,
I have a 1.5 year old 20k mile TL with the auto (June 13 Purchase). Under decent throttle input (shifting above 3-5k) the front of the car seems to have a vibration under acceleration. Kind of like wheelspin, but I know there isn't and like an out of balance tire but their isn't.
It ends as soon as I let up on the power or use less power. It almost feels like something is grabbing all the way through 1st and 2nd gear.
Anyone experienced this before? I want to take the car in, but I doubt the techs will find anything. I am starting to hate this transmission from its horrible 1-2 shift quality to these issues.
Thanks.
Old Dec 1, 2014 | 12:43 PM
rahawk79's Avatar
same issue, are you lowered? I recently installed Coil Overs and once I dropped it I realized it. I was thinking it was something to do with the alignment being out now or the axles maybe because of the new angle...I plan on taking it to the dealership if a needed alignment doesn't correct the issue
Old Dec 2, 2014 | 07:44 PM
csmeance's Avatar
it's probably VSA holding back the power because the computer is seeing wheelspin. Better tires plus turning off the VSA might help.
Also I know from 2006-2008 the TL had the ECU changed to limit torque in the first 2 gears to keep transmissions from failing faster. It might be the same with the 4G TL. I've never really noticed a vibration but I have felt the "grabbing" feeling you describe.
I have the Michelin MX4M's on my TL and they certainly aren't a performance tire.
Old Dec 3, 2014 | 06:29 PM
Jaco's Avatar
My car is 100% stock. It is kind of weird it happens in 2nd and 3rd gear as well. I'll see what happens without the VSA.
Old Dec 3, 2014 | 08:11 PM
acrdr's Avatar
Bad axles
Old Dec 4, 2014 | 08:27 PM
Jaco's Avatar
Tried it again tonight with the TC/VSA off (if i hit the right thing) and I still felt the vibration in 2nd and 3rd gear.
orkoTL
4G TL Problems & Fixes
107
Sep 28, 2017 09:12 AM
jamestheunderdog
Jul 19, 2016 07:58 PM
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
Skirmich
Sep 15, 2015 06:41 PM
thisisnotdave
Sep 8, 2015 10:02 AM
