2012 TL Sunroof and Passenger window help.....
Old 08-04-2018, 03:57 PM
3rd Gear
vstec's Avatar
so i have an odd issue..... the front driver and both rear windows all roll down like they should from the driver switch bank. the sunroof and pass window wont open/ roll down. ive checked all of the fuses and relays, took the pass door panel off and everything looks fine. all of the windows and sunroof open when i use the fob open feature. not sure what to do here
Old 08-04-2018, 06:27 PM
3rd Gear
vstec's Avatar
also to add everything (window switches and sunroof switch) works perfectly when accessories is on. When I start the car and it’s running it doesn’t work.
Old 08-04-2018, 09:59 PM
csmeance's Avatar
Received 2,004 Likes on 1,424 Posts
I'm thinking bad ground if it's happening with the car running.
Old 08-04-2018, 10:32 PM
3rd Gear
vstec's Avatar
Could you be a little more specific with what ground I need to check? Thanks for the help.
Old 04-09-2024, 07:28 PM
mdb007's Avatar
Just found this old thread and same thing happened with my 12 today when wife was driving it. Fyi I hate Honda electrical gremlins they suck!
2011TSXer
02-26-2017 06:23 PM
kl323
1G RDX Problems & Fixes
02-14-2011 07:27 PM
gte401e
07-27-2007 07:36 PM
gte401e
06-27-2007 06:48 PM
Quick Reply: 2012 TL Sunroof and Passenger window help.....
