2010 Tech 3.5 TL
Old Feb 24, 2022 | 05:33 PM
Jared Rodriguez's Avatar
4th Gear
2010 Tech 3.5 TL
about 2 months ago, I had gotten an engine swap with 40k miles since my old engine has a misfire and then had no compression on a cylinder. Once it was done it would run and drive good, just used a lot of gas because it had a emission light on and occasionally threw a bunch of codes like abs, t/c, esp, and clouster would stop working. About 6 weeks later it threw a code about needing oil so I added oil and then a few days later I accelerate weird exhaust noise a few mins later it starts knocking and shuts off. I don’t know if seized or it’s something else. Car had a new battery but when I try to start all it does is click once and turn off cluster lights and come back onVideo
Old Feb 24, 2022 | 05:37 PM
4th Gear
Did not mean to post that picture lol and don’t know how to get rid of it
Old Feb 24, 2022 | 05:47 PM
csmeance's Avatar
Removed that other picture for you. Did the mechanic say anything about the emission light? If you are using a lot of fuel, it's either diluting the oil causing issues or being burned off and running the catalysts full of fuel which can cause issues too.
Old Feb 24, 2022 | 10:49 PM
4th Gear
Thank you, and he had said it was about the car needing an O2 sensor and catalytic converter. But the car stopped running and just clicks now like in the video.
Old Feb 25, 2022 | 09:30 AM
dzionny_dzionassi's Avatar
https://vimeo.com/68163457
Most likely seized. Put your car in neutral or park, try to rotate engine's crank clockwise with a ratchet. If the engine is not rotating, you'll need new engine...
Old Feb 25, 2022 | 11:21 AM
4th Gear
Thank you! I’ll have to do that when I home, but I’ll update after I do it
Nick2618
4G TL Problems & Fixes
14
Jun 12, 2021 09:03 PM
rsteagall
Oct 11, 2018 06:43 PM
Dbuck
Sep 18, 2018 10:28 PM
iCrap
Sep 26, 2014 10:05 AM
Hoffyswoman
Feb 1, 2013 05:35 PM
