Anyone else loves this?
Old 10-20-2014 | 11:08 PM
Grigio4G's Avatar
And by love I mean dread. lol
#lowlife oil change. I like changing oil its getting her up there such a pain.
Anyone has any easier suggestions?
Old 10-21-2014 | 12:50 AM
real_mckoy's Avatar
is it the same process taking it off the ramp using the books? or you can easily back it down that's alot I know its worth it a priceless feeling when changing your own oil but with your addition lowered + kit you should have the dealer change it imo tho so you dont damage anything or get hurt in the process unless someone is spotting you to get it up correctly (pause). Get the ramps that are lower than the yellows ones you have I think advance have the black ones that has low inclines..
Old 10-21-2014 | 07:55 AM
lift3d_'s Avatar
rock the block
i do the exact same thing except i use these concrete blocks that normally border a garden, like this:
not much else you can do. I always have someone else there to make sure I'm straight, i've gotten pretty used to it. I hear beams of wood would work fine too.
Old 10-21-2014 | 08:08 AM
a low pro jack will be easier.
Old 10-21-2014 | 08:29 AM
ucf_bronco's Avatar
What ^^^ said.
I bought one from HF a while back that is low profile but also extends up to 24". That way I could get under the TL but also get the back or front wheels of my wife's Pilot off the ground at the same time. I expect I'll be able to do the same with our new Odyssey when the time comes for its first oil change.
Old 10-21-2014 | 01:47 PM
carbonTSEX's Avatar
The Original Shawdy
Yeah I agree with both these guys above me. I picked up a low profile jack from Harbour Freight as well and it goes just as low as a stock jack. Perfect for us super low guys. Makes the work 10x faster and easier. It's still boxed up though haha.
I should of bought it along time ago when I had my crushed TSX. Im so use to using stock jack just to get my regular 3.5 ton jack underneath my cars. I paid $80 for the jack and its high quality. They have them on sale currently I believe. I receive their add all the time.
Grigio4G (10-21-2014)
Old 10-21-2014 | 01:51 PM
if you get the steel low pro jack from HF it'll jack the car up with two pumps.
the aluminium version needs more muscle to jack up
but its sooooooooooo much easier than messing with ramps.
I chose the small portable aluminium version of the low profile jack from HF
buy another set of stands and you could have the car up on all 4 corners easily.
Old 10-22-2014 | 11:56 AM
also, get the highest lifting low pro jack available.
i didnt catch the lift height and wish it went up another 2 or 3 inches.
nothing a self made stair stepper out of wood cant fix but still, would love if i bought the higher lifting version
Old 10-25-2014 | 04:51 PM
Steven Bell's Avatar
I say install a lift in your garage!
The following 2 users liked this post by Steven Bell:
Grigio4G (10-25-2014), Terragotti (10-28-2014)
Old 11-09-2014 | 05:32 PM
ron3.7's Avatar
Boards
Get a wide board about the size width of your tire about 8ft long cut a piece about 4 ft long and another piece 2ft long and another piece 1ft long and screw them together on top of each other like stairs and drive on up easy simple and cheap just got to go to Home Depot or any hardware store that sells wood. Buy two 8ft pieces because your going to need them for both tires
Grigio4G (11-13-2014)
Acura604
2G RDX Photograph Gallery
17
02-08-2021 03:32 PM
08KBP_VA
10-22-2019 01:55 PM
adrian_s2k
1G RDX (2007-2012)
23
01-12-2016 04:25 PM
AJRozsa
10-05-2015 07:50 PM
Quick Reply: Anyone else loves this?
