5000k!
What brand did you use? I just ordered a PIAA H11 Extreme Bright set and a set of H3 Sylvania for DRL's. I am still thinking about a set of D2S for the HID's but I am going to wait until I install the DRL's and fogs to see how good or bad they look with the HID's.
I am definately digging yours. Very white and very bright! Can't knock that!! Let me know what brand you used.
i used mobile hid for the fogs.
nice nice~~
well...that picture I see you changed the fog light; but what about the headlight?
You said you change the headlight and fog light right?
The picture you post only show the stock HID light turned on right~??
You know what I mean?
took me about 45 min for bumper removal and installing the fogs. i mounted it on top of the bumper support.
i highly doubt the fogs caused my car to stop running. the dealer replaced my battery a fuse, so if it goes out again then i will know.
dont you just love how those grooves/cuts in the headlight bezel, make it appear to "almost" look like Audi LED's
i know its getting done ALOT to the 3G TL... some look classy, others look terrible.. but i think if done right, and contoured properly, it would look really classy in the 4G
If you do, check out the Hoen Endurance. You can plainly see the beam they throw under the HIDs, nice, flat & wide. And really YELLOW. Definitely a + for visibility in ugly visibility conditions.
Thanks for the tip. Where I live we have a lot of fog and snow storms so I figured they would come in handy.
I'm trying to see all the options for fogs before I make a decision. I'm eager to see Blackura's result as well. I'd also like to see pics of the 5000k Cosmic White Nokya's for fogs.
you will experience big loss of vision esp, in raining condition. I tried 6000K 5000K both, but I finally settled on D2s4300K+ bulb. I wouldnt go no more then 5000K if more bluish color is desired.
i have a question regarding upgrading the fog lights to HID. Do have to replace the 10 amp fuses to 20 amp? do you have to do any additional wiring because of the fuses if you have to change them? Or do you buy a kit, say Kaixen, and plug and play? Any detailed info would be greatly appreciated.
