Ktuner- The first tuning solution for the 4G TL
#281
I second that boost question. I have about $7,000 burning a hole in my pocket. I either need to make this thing go faster and have it as my year round car, or buy a go-fast toy for next summer.
#282
You will need way more than 7k to make it fast anyway, so your better off buying something else.
#284
So I'm probably going to pull the trigger on the KTuner this week, didn't realize it was out - I haven't logged in for awhile, busy tending to our first child
With that said, I have a '10 SH-AWD 6MT and my wife has an '11 MDX SH-AWD. Can I tune both vehicles with one KTuner? I can't seem to confirm but it would appear what you're buying with the package is an OBD2 interface and the tuning software. The OBD2 interface doesn't have to stay in the car (I assume?) so I would think I could flash both vehicles with one kit. Is this a correct line of thinking? Hers will stay stock.
I'm talking with a gentleman here to buy his used XLR8 V1 J-pipe with test cat, and possibly look into HFPC's later, or since I don't have any emissions testing here, getting right of the main cat altogether and defeat the CEL with KTuner. Does this sound like a reasonable plan? I'll save up over the winter for a set of Tein SA's since my car is approaching 95k on it and I'm sure a fresh suspension would do it a world of good, though it's not exactly offensive at the moment...
Thanks for any input!
Todd
Todd
#285
Todd
Todd
It is true that you do not need to have the unit plugged in to the vehicle all the time, basically it is used to flash the ECU with revised maps as you tune.
The Tein SA is a great coil over to purchase, adjustable dampening provides you with the option to tailor the ride to your comfort level.
#288
I just installed some RV6 HFPCs this weekend to go in addition with my V2 J-Pipe and Takeda Intake. Now I've got my sights set on the KTuner upgrade next. My stupid question of the day is...
If I were to buy the KTuner online, can I plug it into my OBD2 port and reflash it myself? Or is it mandatory that when I buy this tuning software, that I have to take it to a shop that has a dyno for them to flash it and tune it to my car?
Also, if I just went to an authorized installer, would a KTuner install be cheaper than buying the actual KTuner device? What are the cons to doing this? (aside from not being able to return your ECU to factory settings whenever you wanted).
I hope my questions are legit!
#289
The end user kit allows you to flash it yourself.
If you don't want to flash it yourself you can have a KTuner dealer use the dealer flash tool to flash it, but as you said you won't be able to make any changes or flash back to factory.
#292
#293
Thanks for the reply! I have another question... So the KTuner base maps were created based on tuning a TL in the Chicago area, is that correct? If so, that means that the pump gas was probably purchased in Chicago, which gets all of their gas from the Whiting, IN refinery. Indianapolis also gets all of their gas from that same refinery. So if I elected to just install the base maps from KTuner, then I should theoretically make the same power because the fuel is the same, right?
#294
All I can say is, I'm happy of the results I got after the tune. It is expensive, cost me almost 1K overall for the kit and tune. That is not including the performance hardware. 4G runs very lean from the factory alone. Well worth the money if you want the best performance out of the 4G. Smooth power delivery throughout the rev range; right until the VTEC engages there is a slight bump. Pulls nicely thru all the gears. I'll rarely hit the peak hp though since it's at 6700 rpm.
KSeriesTuner (11-18-2015)
#295
#296
No sir. Custom tune.
#298
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
HeartTLs (11-18-2015)
#299
1K eh? Did you buy the stand alone kit ($499) and then have the car tuned by another shop (assuming it was +$500)?
I'm just trying to find the most inexpensive way to get KTuner on my car right now and get power gains. I am sure that a person tuning my car would probably be able to extract maybe 5 more HP than the KTuner pre-loaded maps for a J-Pipe and HFPC combo, but what I'm seeing as the most bang for my buck is just paying $299 for an authorized installer to reflash my car and then I'd have a 90% solution for the best gains I can get just short of having a full custom tune.
#300
#301
Former Sponsor
The $299 is a great bang for the buck, but i think it really depends on the amount of modifications your car has. If you just have a intake and catback, the Ktuner base tune would be fine and you probably won't see tons more power with a custom tune.
If you have full HFC exhaust, intake, pulley, etc. then you I think going with a custom tune would be the better option. Typically, the farther from stock you are the more the tune needs to be customized.
#302
So far from the readings I have yet to se any real benefit of a aftermarket intake system. Sounds like a good exhaust upgrade and a K&N filter swap just does the trick. Has anyone here been able to tune with the ice box or that short ram and seen any efficient number gains?
#303
Cruzan I'm tuned with the icebox and have gains, but no numbers to prove it. From datalogs Kenny was able to determine that airflow and velocity was best with CT-E, then stock. From other users he determined that stock was better than SRI, so I believe it's safe to say CT-E, Stock, then SRI. That said the SRI was tested on another vehicle with different mods than my own.
#304
#305
Anyway,
I know I have asked before, buuuuut.... I have XLR8 V2 J Pipe and CTE. Thats it. With the provided tune, I should see a performance gain right? E-tune will follow in the spring.
Thx
#306
Former Sponsor
![Arrow](https://acurazine.com/forums/images/icons/icon2.gif)
KSeriesTuner (12-05-2015)
#307
I swear I am close to ordering the K-tuner but I have a 7 year itch for a Z06 that I might have to scratch first. I will post details if it goes through. I might be in the minority, but Chevy's and Honda's are my favourite brands. Give me Small Block Chevy's and Honda J Series motors and I am very happy camper.
Anyway,
Thx
Anyway,
Thx
#308
I have J-Pipe, light weight pulley, sprint booster, ATLP exhaust, CT Air intake, Throttle body spacer, Manifold spacer and I am about 80% done on my e-tune. I know I will get flamed but the car is stupid fast for a daily driver. I actually can't remember last time I went it higher RPM's due to the tune. It is very smooth, my VTEC kicks in around 3900RPM. I think it is well worth the money.
The following 3 users liked this post by sympley:
#309
The Original Shawdy
Good to hear and you aren't running precat deletes or high flow precats.
#310
The Original Shawdy
The Ktuner isn't locked to a vehicle. So all you need is everything included in the kit and its a straight drop in correct?
Thanks guys!
Thanks guys!
#311
If you ever decide to sell the unit then you can unlock it from your ECU and return to stock tune.
carbonTSEX (12-12-2015)
#312
Also the ktuner should be safe correct? As in my motor won't be getting any problems because of the tune down the line? I know it's only been out for a few months now so it's hard to really know. Probably going to buy one for Christmas. Thanks guys
#313
The Original Shawdy
Same. There is one for sale in the black market for $350 shipped. Steal. Wife wants me to buy new though.
#314
It is only an interface between your ECU and the tune, after your tune is uploaded it is removed and only used if you need to update your tune or return to stock.
#316
I think I am getting it dyno tuned at Xenocron in New York. They work with Ktuner and I've heard they are very good tuners. Has anyone gotten their car tuned with them?
#317
#319
The owner at Xenocron is an excellent tuner and from what I understand he may be bringing on a second tuner who's also very good as well.
If you buy used make sure to confirm it's unlocked by the seller first!
#320
Do you have a list of tuners you can recommend in the North East, Penn, Ohio and even Michigan that would have a AWD dyno.
