Ktuner- The first tuning solution for the 4G TL
#604
Glad to hear you found a difference with the base tune without any mods other than the muffler. I am thinking of ktune as well sometime in future. I had been looking at jpipe (I might still do that at some point as well), but it seems like the ktune on its own might be almost as good as ktune as jpipe. TBH I got lost in the dyno posts because I thought it looked like the ktune+jpipe combo was giving some nice addititive gains when i looked at the dynos earlier in the thread but other have looked at the dynos and not noticed much advantage to the combo.
A question for those in colder climates...any issues with using the tunes in winter?
#605
#607
The following 2 users liked this post by cb169:
losiglow (02-07-2018),
RailTester (09-18-2017)
#611
Any issues with the pulley? I've been thinking of eventually getting the xlr8 one or a stock j37 one, since it's already a bit lighter than the one on the j35.
Does anyone have any clue about drive line power loss on the AWDs? I can't see there being much of a difference power wise between the fwd and awd with what I imagine are higher losses.
#614
#616
2013 TL SH-AWD TECH 6MT
Hi,
Bought a car from a dealer about a month or so, it's a 2013 TL SH-AWD 6MT with Takeda Intake and CT-E Axle Back Exhaust. Told me the previous owner got it tuned, never really believed him since i had no proof, but the car does pull off a lot. By reading the post in this thread, i start to believe it was really tuned by a Ktuner since my max rev is 7100RPM and i have no speed limiter, so far i pulled 225KMH (140MH) in 5th gear @5000RPM (so still 2100RPM to go and 6th gear), laid off the gas but the car def wanted more, its hungry, could prolly go over what the max limit is written in the dash. Anyways still can't figure if it was a custom or just a base map, also have no dyno numbers and since i want to put in a custom X PIPE configuration, i ll have to get it tuned again anyways... Any other obvious clues i could look for to know what has been tuned ? What Ktuner base tunes actually covers ?
#617
Hi,
just1nsama (09-20-2017)
#618
#620
Hi,
#621
A 2013 with a CT-E exhaust? interesting,,,, you luck up. And my 6 speed 2011 not fully tuned yet redlines at 130mph (209KM) in 4th gear with 4 pulls Etuning down in Mexico. So in my opinion I'll say other wise. And having that ram intake it is recommend to have it custom tune. The base maps for ktuner even says so. Also if your getting all other bolt ons you might as well get the Ktuner and tune it right.
Thank you for your input.
Justin
#622
My point was the fact that i can hit 140MPH and up, speed limiter was removed so some tuning must of been done using Ktuner, was it enough, i don't know and yes like you said, after putting my custom X PIPE exhaust (depending on the quote) and by that i mean fully opened from top to bottom 3", will def get a Ktuner and have tuned. When you say you redline in 4th at 130MPH, are you saying the car won't go above that or you re just letting it go, because i def hit that speed in 4th gear since im not even near redline at 140MPH in 5TH gear. What mods do you have right now and what whp were u hitting during your tune up ?
Justin
Justin
#623
Hi,
I'm not saying I don't believe you, but whats odd about that is ktuner binds to one ECU, meaning for the previous owner to reuse or sell the unit he or she must unpair it from the TL, which reverts the vehicle to a stock map. Maybe you REALLY lucked out and he/she forgot to do that? BTW cherish that CT-E axle back, i've been trying to get a hold of one for months and havent been able to. Any pics of your rear?
carbonTSEX (09-21-2017)
#624
#626
HeartTLs (09-21-2017)
#627
#629
#630
It's temperamental. Unfortunately ktuner is missing a few lines of code to run cams properly so sometimes my car is running 100%, 0 lights on the dash, and fast as hell. Sometimes, my dash looks like a christmas tree, yet everything runs well, other times I'll have a code or two go off and its tedious to drive and lastly but nothing new to me now, the car will just about be unbearable with a 3k rpm limit until I shut her on/off. What I just said may sound more negative than positive, but that doesn't reflect how I feel. There's disappointment, BUTTTT overall my car hauls and feels amazing to drive.
#631
#632
Can you guys elaborate? If you upload once and upload the same thing again, nothing changed vs the first time. Not catching what you're saying, unfortunately.
#634
I ran into some difficulties during the drive-ability/street tune portion of my dyno tune with Derek. A 3k rpm limit would periodically kick in. What I understood from what he told me was that he would be sending you a datalog to see if you could diagnose the problem in the ecu and hopefully address it with ktuner software. Maybe I misunderstood? Or maybe as a layman I'm doing a poor job of explaining the situation.
#635
What code is it? Currently a dealer has submitted for knock sensitivity, but I have nothing else on the docket.
#636
HFPC or PCD
Is there any truth to what I have been reading on social media and a few threads regarding issues/failures with the HFPC?
If you choose to go PCD your literally unable to pass emissions so how is that even an option in most states?
Ktuner indeed seems very promising, hope to pick one up soon.
#637
I just came back to say that this car pulls like a bat out of hell after the tune! I have been driving it pretty mellow, but today I gave it the beans for a bit. At about 5500RPM it just PULLS all the way to 7100RPM. It pulls so much harder than before up high that it feels like a totally different car.
I also went for a road trip this summer, took some out of nowhere country roads. Top speed... well past the gauge max of 240 kph. I am guessing I hit 250 (155 mph). Car is NOT designed for that! The wind buffeting was a little bit much, probably the last time I ever go that fast in this thing! It is fine at about 220, but any faster than that and the wind starts to really play around a lot.
The following 3 users liked this post by blackkramer:
#638
It really does bring it to life. Glad you're enjoying!
#639
#640
Did u load one of the base tunes, or tuned on a dyno/street tune?
