Honda Brake Fluid good for track use?
Old Jul 8, 2011 | 04:34 AM
Samba's Avatar
Has anyone taken their 4G TL to the track? Is Honda heavy duty DOT 3 brake fluid good enough for track use? If not, what do you put in your car? Thanks.
Old Jul 8, 2011 | 07:41 AM
Pseudomaniac's Avatar
Are you going to run a professional tarmac circuit and try to outpace an M3 through the turns, or are you just going to auto-x in the cones? Big difference in your needs.
In either case, you'll exceed the abilities of the stock pads/rotors/tires long before you run into brake fluid issues.
Stick some drag radials on there, drop the suspension 2 inches, and running on some 8 pot brembos with 18" rotors - okay, maybe you'd thinkg about lines and a flush / refill with RedLine....
mada51589
Jan 9, 2025 04:40 PM
nanos
Nov 12, 2015 08:41 PM
ulrblitzer
Sep 24, 2015 07:42 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
NSolace
Sep 3, 2015 08:02 PM
