The Bottom Line - Do Performance Chips Work?
Old Jun 25, 2011 | 02:27 PM
No_Secrets's Avatar
Guys,
I have a 2011 TL with the 3.7 motor and I want a little more power. I have been doing a lot of research on Performance Chips.
I have concluded that there really is only one company I would go with.
http://www.engineperformancechip.com/
Now I am not 100% sure it will work, however, for the $150 I am prepared to try it. It looks like the X3 chip with the O2 sensor control is the way to go.
X3 Performance Chip with O2 Sensor Control - $150
Power Performance Chip X2 - $69
It would appear based on older posts that the Performance chips don't work on our cars, however, I will challenge someone to show me proof? Maybe the performance chips work on newer Acura's? I have yet to find anyone on the web that has had success so I am skeptical, believe me.
If anyone can shed some light on this I would appreciate it.
Thanks,
J.
Old Jun 25, 2011 | 02:37 PM
fake. dont do it.
there is absolutely no way to tune these v6 motors.
we do have a new ECU available for the 3rd gen TL, that can be ported over to the 4th GEN.
Originally Posted by KN_TL
I've gotten some information on the upcoming ECU product.
It is based on the MegaSquirt3 ECU modified to interface with the 3G TL ECU.
MS3 info is here http://www.ms3efi.com/product.html
Here are some things you can control (Items are hyperlinked)
This also means that the tuning can be performed using MS compatible software. The current software being used is TunerStudio. It can be downloaded for free and also has a register option. More information is available here:
http://www.efianalytics.com/TunerStudio/
One HUGE feature is VE Analyze Live. Read about it here:
http://www.efianalytics.com/TunerStudio/#veAnalyze
Some questions and answers so far:
Q. Will the stock ECU be retained ?
A. Yes, this insures that all factory features are not lost
Q. If the factory ECU is still in place, are you simply intercepting the signals?
A. No, the FACTORY ECU has no control over engine parameters.
Q. Will this be a Plug and Play install or do I need to custom wire?
A. This solution will be Plug and Play with a pre-wired harness included.
Q. Are Base Maps Included?
A. Base maps will be available based on the application.
Q. What is VE Analyzer ?
A. A tuning tool that tunes while you drive! See http://www.efianalytics.com/TunerStudio/#veAnalyze for more information.
Q. Is drive by wire retained?
A. Yes along with all other luxury features handled by the stock ECU.
More info, Email - tl20046speed@yahoo.com
Your "CHIP" only claims horsepower increase. where as this new ECU, you can control all those parameters I quoted above.
also, your "CHIP" says it works for 1996 to 2012. You do know that there are different Engine chassis codes? How does the "CHIP" know which car it is. oh, its one of those "all purpose chips"
The New ECU that is available is pricey at $1400, but is able to dyno tune our cars and able to control all of the parameters quoted above.
We have several Turbo members who are using this new ecu. they've obtained goals of 500HP.
We've always had trouble tuning our cars, as there are no chips available. Now this ECU is a major game changer and will allow J32a3 swaps into civics and such, and allow typical "hot rod" mods for our cars, including changing out the Cam to a more aggressive one.
Old Jun 25, 2011 | 03:03 PM
Also, what the 2nd gen community found was that the these chips that did change the air/fuel ratio, our stock ECU would overwrite these values making the chip null.
Same as the third Gen TL, the guys with the Comptech Supercharger are having problems with tuning. As our ECU's just flash back to stock, or the AFR Reverts back to a normal rate.
COntact J&R as they are interested in a 4th gen TL test subject.
https://acurazine.com/forums/4g-tl-performance-parts-modifications-295/jandrnextlevelperformance-looking-first-4g-turbo-tl-819261/
Here's J&R's site.
http://jandrnextlevelperformance.com/
Feb 25, 2020 09:57 AM
yesSIR-S
May 13, 2016 05:42 PM
acurajj
Sep 19, 2015 03:47 PM
Sixers12
ILX
Sep 6, 2015 07:54 PM
