The only thing I'd point out is the gas pedal is just the aluminum cover. The assembly I purchased is the whole gas pedal assembly and DBW stuff. There is going to need to be permanent modifications (holes drilled) in the stock pedal for this to fit.
has anyone tried these sport pedals???
https://www.uniquestyleracings.com/index.php?route=product/product&path=60_62_127_342&product_id=459
they are offered in manual as well.
Was 30 bucks. The Acura Logo is embossed, not a sticker or paint. Rubber is super thick, won't be worn down anytime soon. Metal is really light and seems strong. I had to buy new screws because I torqued out the ones it came w/ so they didn't look nice. But that was like another 2 dollars at home depot. It came w/ locknuts too. I used permanent loctite on it so I shouldn't be having any issues at all.
Has anyone tried to use Strut King TSX (04-08) pedal set it looks just the same as OEM Acura TSX (09-14) pedeal set? If the Strut King gas pedal cover fits I think I will go this route vs buying the OEM Acura TSX (09-14) gas pedal.
I installed that manual set from Strut King for a TSX in my 2014 TL and looks and feels great. Awesome upgrades from stock. You would need to modify it a little to make it fit but nothing you can't handle. Simple mod for sure. 30 mins to install tops.
What, exactly did you have to modify? Please give details for the guys interested in making this work for the 6 speed...
The only thing that needs to be modified is the the TLs footrest. It needs to be cut about a centimeter on either side to be able to fit in the chrome footrest that comes with the TSX kit. All the other stuff is pretty much self-explantory. Just follow the direction and you should be good. The tools you need will be a drill, screwdriver and a 7mm socket wrench. Drill a few holes into each pedal and install and you are golden. Their is also some videos on YouTube too that you can get some pointers on. Good luck.
