Which wiring harness?
Old Jan 14, 2016 | 09:31 PM
Pgr1990's Avatar
There are a lot of wiring harnesses on the car, I was wondering if anyone knows which one the horn and headlights are connected to. I need a new harness and can't figure out from the diagrams which is the correct one to order.
Old Jan 15, 2016 | 09:28 AM
Duct_Taper's Avatar
According to the service manual the horns and left (driver side) headlight are connected to the left engine compartment wire harness and the right (pass. side) headlight is connected to the right engine compartment wire harness.
Both harnesses are pretty extensive and pass through the firewall to connect to a bunch of stuff behind the dashboard.
EDIT: Based on comparing the service manual diagrams to the parts diagrams on bernardi parts, it looks like the ones you want are probably "WIRE HARNESS, L. CABIN" under WIRE HARNESS (1) and "WIRE HARNESS, R. CABIN" under WIRE HARNESS (3). That's based on a '12 TL Tech Auto though so YMMV depending on your year/model.
Old Jan 20, 2016 | 09:19 AM
Pgr1990's Avatar
Mine is a 2012,
Thanks for the help
DJMikeT
Jan 12, 2016 12:15 AM
Budnotbuddy1
Jan 7, 2016 07:36 PM
