Stream music from iPad to 2010 TL Tech?
Old 05-20-2011, 09:17 AM
4th Gear
sigmachikansas's Avatar
Hey all-
Might be a simple fix but I was wanting to stream music via bluetooth from my iPad to my TL. I know how to set up my iPhones on the bluetooth however dont know how to set up the iPad (if I can). Can anyone offer the steps to doing so?
I just envision tailgating, camping, etc and controlling all of my music (coming from the Acura) from the iPad. Tech geek!
Old 05-20-2011, 09:37 AM
Colorado Springs
prepreludesh's Avatar
I have done this no problem on my TL.
Just turn the bluetooth on on the iPad. Then make sure the phone that you've normally paired with the car is turned off and then press the aux button on the TL and it will probably ask you to input the 4 digit code. Then you're good to go!
For this reason, I wish they would've made the iPad able to do phone calls, because it would be very convenient while in bluetooth mode in a car. Oh well. The car can't really charge the iPad from it's USB port because the iPad is using more power than the car is supplying while using the iPad.
Old 05-20-2011, 09:45 AM
4th Gear
Thanks! That actually kinda segways me into another question I had. If the wife and I both have iPhones, but shes the primary driver of the TL, should I just not bother syncing my phone with it to avoid problems?
Old 05-20-2011, 10:05 AM
Pseudomaniac's Avatar
if you have different fobs - it remembers your contacts and settings by phone/fob and can handle multiple phones. The iphone contact sync takes a while, but after that, the quick dialing is nice.
If you both carry iphones, I'd say leave the ipad at home.
The bluetooth is funky, and it's the iphone/ipad, not the car so much. Most of the time it works fine, but occasionally you'll have to go to settings and turn the bluetooth off/on on the i-device to get them to talk again. I use mine for Pandora mostly, and MOST of the time, when it syncs up - even the steering wheel skip button works - just not all the time.
Old 05-20-2011, 01:27 PM
akiko2012's Avatar
has anybody ever experience a delay on the skip fuction using the steering wheel buttons? ...usually when using the music ipod function of the iphone.
Old 05-20-2011, 02:32 PM
RIneuron's Avatar
There is always a delay of about 2 seconds when using iPhone over Bluetooth in my experience. It has never failed to work for me. I have a 2010 non-tech SH-AWD.
Old 05-20-2011, 07:11 PM
akiko2012's Avatar
^^^^ can you play and pause using Acura's BT menu?
Old 05-23-2011, 09:07 AM
The steering wheel rocker buttons work with some iphone/ipad apps for skipping, but I've never seen a play or pause function on screen for any of them.
snorf
11-04-2019 06:44 AM
copmagnet82
3G MDX (2014-2020)
71
11-05-2015 08:29 PM
IlliniAcura
09-19-2015 09:31 PM
RenoTL
09-17-2015 07:45 PM
iRaw
ILX
09-05-2015 12:10 AM
Quick Reply: Stream music from iPad to 2010 TL Tech?
