Rear Deck Speaker QUESTION 2010
Old Oct 1, 2010 | 03:58 PM
Mlauderdale1000rr's Avatar
2010TL, 07 600RR, 06 1KRR
Hello,
Does anyone know if they drop in from the top or unscrew from the trunk? Im praying they drop in from the top
Old Oct 21, 2010 | 07:20 AM
Wimpy's Avatar
The rear tray has 2 17cm Speakers and a 20cm Subwoofer - they are all installed from the Top - the Subwoofer has a spacer underneath the Frame that mounts to the vehicle, be careful when trying to replace to "upgrade" the Bass... The rear deck is a little weak and you may have some buzz/rattle issues by changing the resonance / weight of the subwoofer that is currently in it. That is the purpose of the thick metal ring on the bottom of the subwoofer.
Old Oct 22, 2010 | 10:13 AM
mikechampion's Avatar
9th Gear
I'm having problems with vibration with my rear deck on some songs with a lot of bass. Is there something i can add or do to get this stopped?
I have an 09 AWD Tech TL
Old Oct 22, 2010 | 03:53 PM
SSGHutch's Avatar
I had dynamat installed on mine, no rattles at all now.
Old Oct 31, 2010 | 04:07 PM
BKComet's Avatar
Can you provide any tips on replacing these speakers? Specifically removing the rear deck cover to access the speakers. Also do you know the hole sizes for the 3 speakers.
Old Oct 31, 2010 | 09:04 PM
ALsAcura's Avatar
First remove the bottom rear seat by pulling the tabs on the release clips, after the bottom is out there will be for bolts at the bottom of the rear seat, remove them and lift the seat up and out it should come out with a little bit of effort. Beware the bottom of the rear seat has sharp edges and will scratch the paint off your door jams so get someone to help slide it out its a tight squeeze and its bulky.
No that the seat is out remove the left and right pillar covers by prying them toward you they should pop right out. Now just pop up the rear deck make sure you get all the plastic fastners one or two may fall out of the deck and stick in the rear of the car.
And thats that the rear speakers are 6 1/2 and the sub is a 8" Good luck.
Old Aug 29, 2017 | 11:04 AM
Andy Aquino's Avatar
Do I have to take out the seats, I bought a used TL and I don't have the original key to unlock the access door that is under the armrest
vaughanml2
Nov 1, 2021 10:16 AM
Feb 25, 2020 09:57 AM
Heyzuez20
Oct 14, 2015 07:18 AM
Dunnik
Sep 15, 2015 11:52 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
