Is the Navigation Code the same as the Radio Code?
Old 03-28-2009, 01:05 PM
7th Gear
hydro's Avatar
I only received the Anti-Theft radio ID card when I took delivery of the car. Does this code also work for the Navigation system too?
TIA,
Mike
Old 03-28-2009, 08:36 PM
GearDriven's Avatar
Nope, it's separate. Check your owner's manual booklet. I think it is printed on a card.
Old 03-28-2009, 10:20 PM
KeithL's Avatar
I only have one code for NAV and Radio and still have not gotten a straight answer from anyone at the dealership, I keep meaning to Acura. The printed card as well as the stickers in the glove box and center console show one number only.
Old 03-28-2009, 10:30 PM
GearDriven's Avatar
When the valets killed my battery, I had to enter two codes I'm pretty sure... I will check again tomorrow.
Old 03-28-2009, 10:45 PM
5th Gear
3srwild3's Avatar
I had a similar problem, I called Acura and they can get you your Nav code if you give them the serial # off the back if the Nav unit (At least my place did). It is pretty easy to pull the Nav out...
Old 03-29-2009, 07:32 AM
7th Gear
hydro's Avatar
Can you please let me know where the Navagation unit is located at so I can get the serial number?
TIA,
Mike
Old 04-01-2009, 08:23 PM
djavenger's Avatar
I only have one code as well. Does anyone have two codes or does the one code work for both?
Old 04-03-2009, 05:09 PM
Nodnarb901's Avatar
FWIW, I work for Acura and bought an 09 TL-SH-AWD that only came with a radio code and no navi code as well. still can't get an answer on this either.
Old 04-03-2009, 08:37 PM
Yea, It's Me!
PGSberg's Avatar
I was told by the service department that both were the same. I went through this when I tried to register with Acura's web site and service. I went back and entered the same code for both and it let me finalize the registration.
Old 04-03-2009, 09:14 PM
djavenger's Avatar
I spoke with the Acura service department today and they confirmed that there is only one code for both Radio/NAV.
Old 04-05-2009, 10:43 PM
GearDriven's Avatar
I just double checked and I guess I only had one code...maybe I needed to enter it twice?
Old 04-06-2009, 01:03 AM
x-man's Avatar
The Navi and Radio is now one unit. It only uses one antitheft code.
agupta3224
05-23-2017 08:30 AM
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
navtool.com
31
11-16-2015 08:30 PM
Matthew Purpura
09-25-2015 06:10 PM
Quick Reply: Is the Navigation Code the same as the Radio Code?
