My new NavTool
Old 10-06-2015, 03:54 PM
  #121
sarge_in's Avatar
Got it installed from an installer, and aside from few hiccups during the install it is working great. Even though the Orange wire was pre-wired, he had to cut it to make it work. He ended up chatting with online support and they were able to assist - so props for their support! The directions could be better, though.
I also put in a Micca media player and a portable hard drive in the center console for video during lunch breaks as well as photo slideshows in place of the static Acura wallpaper. Works great!
The following 2 users liked this post by sarge_in:
AcuraKu (01-03-2016), cyberizer (10-19-2015)
Old 10-06-2015, 04:21 PM
  #122
navtool.com's Avatar
Thank You
Old 10-19-2015, 12:57 PM
  #123
5th Gear
cyberizer's Avatar
Can you tell me please, how much did the installer charge approximately?
Thanks.
Old 10-21-2015, 11:46 PM
  #124
sarge_in's Avatar
It was a mix - I got the NavTool, a remote wire and dash cam all installed for $100.
Old 12-27-2015, 08:55 PM
  #125
3rd Gear
Ben Benson's Avatar
Originally Posted by csmeance
most folks connected the old navtool in the trunk to the DVD player drive, and ran power from the center console to the rear or via the fusebox.
Acura TL 2006 accessory wire in the trunk. Navtool 3.0
I tapped a red and yellow wire going in the middle back of the DVD player as my accessory power. I read this in another forum and was skeptical But it worked fine. So far the backup camera is working fine, I haven't worked out the mirroring connection yet. Just in case any1 else is having trouble finding an accessory wire in the trunk.
Old 12-30-2015, 10:23 AM
  #126
3rd Gear
Ben Benson's Avatar
Originally Posted by sympley
Since this is HDMI version do I need to connect the Video Input RCA plugs?
Similarly with the Audio Output there is no need to connect right?
How about the small 2.5mm jack? Does it need to be connected? Is this what is being used for audio from the source or will the audio go via HDMI?
2.5mm output needs to be connected to your stereo because Navtool will send video only to your navscreen. If you have an Aux audio jack you can connect it to directly to your phone. I don't have one but my car has a cassette player so i used a cassette adapter and plugged it to the headphone jack on my phone. Make sure to select tape on your radio. It worked!
Old 12-30-2015, 03:12 PM
  #127
Mjakaz09TL's Avatar
If anyone is on the fence about getting one I am selling mine, just lmk. Nothing wrong w it. Just trying to sell car and it's not used since I rarely drive it to keep miles down.
Old 01-21-2016, 10:46 PM
  #128
6th Gear
priyavadan's Avatar
Which version of the navtool is it? Will it work on the 2006 TSX?
Old 01-22-2016, 09:16 AM
  #129
hi please PM for details
Old 01-24-2017, 11:51 PM
  #130
shekoAKAusher's Avatar
About backup camera🤔
So if you install the navtool 3.0 to the car
it will lose the factory backup camera?
or everything just stay the same🤔
Old 01-25-2017, 12:51 AM
  #131
Blaze9's Avatar
Everything is exactly the same. You have to switch "inputs" into the navtool. Otherwise unless you switch it's like you didn't have any other mod.
If you do reverse when the navtool is switch, it'll auto switch to the reverse camera. You loose the lines, but that's only if you have the navtool input active. Otherwise if you're on the normal nav screens reverse camera works perfectly.
Old 09-23-2019, 09:52 AM
  #132
mrphilipanderson's Avatar
My navtool has been running smooth since I sent it in for Update of the software...But now its doing that disconnecting thing again. Anyone else having this isse? Youre driving along, and carplay just dosconnects then reconnects...intermittently?
navtool.com
Sponsored Sales & Group Buys
87
01-23-2016 01:25 PM
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
Quick Reply: My new NavTool
