(MID) blank screen! Please help
Old Oct 14, 2017 | 12:28 AM
Hendrix's Avatar
4th Gear
Deopped my car(2010 base TL) off at a local body shop for some insurance body work. The Multi information display worked with no problems when I dropped the vehicle off. When I received the vehicle the display has backlighting but no text appears. I can adjust the brightness and even scroll through the different menus, because if I scroll through it will change from a black screen to the orange i maintenance screen but with no text whatsoever. What could be causing / could have caused this issue?
Old Oct 14, 2017 | 11:15 AM
Hendrix's Avatar
4th Gear
Fixed. Technician at acura took apart the dash and found the signal wire was loose on the back side of the gauge cluster.
