Help with USB connection to hard drive?
I'm a newbie here and a new TL owner...
I purchased a 160GB USB 2.0 HDD and loaded it up with about 30GB of music with the hopes of using it as my main music source in the car (2009 Base TL w/ Tech).
When I plug the HDD into the USB jack, I can hear the drive spinning, but the center console just says "LOAD" and the upper (nav) screen says there's "No Data".
Am I trying to use an incompatible HDD, or is the car indexing my music (and it takes a long time)?
Any help here is much appreciated!!
with 30 GB's of music it might be tough for the drive to access it. If memory serves me correct, I think the owners manual said 8GB's on flash drives were the max...
18TLX Elite ASpec CBP/blk
1 Post
32GB USB flash stick works
I was able to use up to a 32GB USB flash drive with about 5000 songs on it with no problems. I tried a 64GB, but it just sat on the "loading" message similar to what vinniepham is seeing.
FYI, you might have problems with portable hard drives, since many of them need 2 separate USB connections to supply enough power to work properly.
rockyboy
01-25-2016 06:00 PM
ja17
09-07-2015 06:08 PM
