Front signal light not lighting
Old Apr 8, 2015 | 07:34 PM
just1nsama's Avatar
2013 TL SH-AWD TECH 6MT
Exclamation Front signal light not lighting
Hi,
I just got a 2009 TL SH-AWD TECH and the left signal was flashing real fast, normally that means the bulb is to be changed so i did (front right turn signal just above the fogs), but turns out the copper connectors in the socket were really dirty and pushed too far in the socket, so even the new bulb would not resolve the issue.
Cleaned it out, pulled up the coppers connectors using a copper stick, put it back in and now the turn signal works just fine when activating before a turn BUT i noticed that when the lights are on, that signal light that should be on like the other one does not light on (But again, it works when activating turn signal).
My guess would be to just replace the socket, but dont want to buy one for nothing ... Thank you for you input.
Old Apr 9, 2015 | 07:53 AM
liquidneon's Avatar
check the rear on the same side as well
Old Apr 9, 2015 | 07:56 AM
just1nsama's Avatar
rear works just fine, not sure you get my issue, the front right signal works when signaling but does not light when lights are ON.
Old Apr 9, 2015 | 08:03 AM
ucf_bronco's Avatar
You may have bought the wrong bulb. Did you get 1157 or 1156? You need an 1157 and I'm guessing you got the 1156 because it only has a single filament. It will still fit in the socket but won't function properly.
If you're not sure just remove the bulb and look at the bottom. It should have two "nubs". One for the constant on when your lights are on and the other is for when signaling. If you remove the other bulb that's working correctly you'll see the two "nubs".
Old Apr 9, 2015 | 08:14 AM
just1nsama's Avatar
I remember seeing 2 nubs, but that would confirm my suspicion that i need to change the socket, maybe only 1 polarity works and that is why i can signal but not get constant electricity flow, will test using the socket from the other side.
Thank you, very informative, will report back with results.
Old Apr 16, 2015 | 11:38 AM
just1nsama's Avatar
Turns out that just cleaning the socket was all i needed, the fact that it didnt work at first is that the new bulb Acura dealer gave me would not function properly for one of its function (even tho it was the right bulb size). Ended up putting back the old bulb and problem solved.
mada51589
Jan 9, 2025 04:40 PM
pizokk1
Sep 23, 2015 11:29 AM
08 NBP TL
Sep 8, 2015 08:49 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
