Front door speaker replacement - Image Dynamics
Old Sep 30, 2013 | 04:15 PM
brison's Avatar
6th Gear
I replaced the front door speakers with a pair of Image Dynamics mid-bass. CX62.
This was my second go at replacement speakers. Originally went with Infinity Reference and was very disappointed. Not sure if it was due to them being 2 way or if they didn't have enough low/mid.
Anyhow, these were a bit of a trick to fit. I had to customize using the stock speaker and cutting all of the "guts" out so that only the spacer part of the bracket remained. Still had to cut away a little more of the bracket to get the driver to fit flush. Then had to mount the bracket to the door - then the driver to the bracket using self tapping sheet metal screws. Seems to be very flush with the door panel so I'm not too concerned with the heavy weight of the speaker pulling the screws loose.
Used Metra adaptors to keep the stock harness in tact.
The sound is good at low volume and excellent at high volume (25+). Overall still seems a little bright. I'm wondering if the RMS values on these and my replacement sub (also an ID product) is having an effect on that.
I am planning on replacing the rear deck next with another set of these, but may opt to go with new tweeters or 3.5s if the RMS will make a difference.
2009 TL SH-AWD w/ Tech
I have a pick of the adaptor ring and will upload as soon as I figure out how.
Old Sep 30, 2013 | 06:37 PM
dwest1023's Avatar
Keep in mind that when Acura or any other manufacturer designs a audio system everything is design to work together. Its better to replace amp and all speakers for the best sound.
Old Oct 4, 2013 | 01:24 PM
TC2010shawd's Avatar
What other door speakers, subs and amps work best for a stock fit with a moderate improvement in sound over the base oem system?
Old Oct 7, 2013 | 05:24 PM
brison's Avatar
6th Gear
I wouldn't have an issue replacing amp if I could keep existing wiring, etc. However, I have to say the system is greatly improved with these speakers and sub. I am +2 on bass settings and -2 on treble. The main thing is how clean it is. I can get to and exceed 35 on volume without feeling like I am stressing the system.
csmeance
Jan 7, 2026 06:25 PM
Feb 25, 2020 09:57 AM
handsom-hustla
Nov 13, 2015 05:04 PM
RK_AcuraTL
Sep 5, 2015 02:26 AM
MyKids&Cars
Sep 1, 2015 12:53 PM
