DVD-A for Acura TL 2012
***Opinions, suggestion advice appreciated
Does the Acura TL 2012 play DVD-A. ?
If it does, how does one create a DVD-A. Is there a particular software that i need to have to write a DVD-A for Acuras?
What format does it support for audio?
https://acurazine.com/forums/4g-tl-audio-bluetooth-electronics-navigation-294/dvd-audio-watermarks-889185/
Cirlinca hd audio solo is well worth the cost you can try 5 for free
http://cirlinca.com/
I will give a quick rundown
Software
Cirlinca HD audio solo ($$) - burns wavs/flacs to DVD-A
dvdaexplorer (free) - used to extract multichannel .wav files from the audio_ts portion of a dvd-a - take an iso image and extract it to a folder then point to the audio_ts folder and choose any .pp file
Foobar (free) - uses a variety of plug ins to play and convert DVD-A, DTS, SACDs to multichannel .wav files
DVD audio extractor (30 day free trial) - rips multichannel wavs from video_ts section of dvd-v or dvd-a
zynewave podium (free) - multichannel wav editing tool ( I use to split tracks or trim)
Software
Software
Software
Awesome Info. Thanks
will i be able to convert MP3 to the DVD-A format and then burn on a blank DVD?
http://www.cirlinca.com/mp3to51.htm
Just because you upsample does not mean it will sound better than it did as an mp3 (you will be able to do 5.1 and that will help maximize the sound system of the TL). Leave the world of lossy compression behind.SACD PS3 iso is your friend and 24/96 is where it's at so walk towards the light.
orkoTL
4G TL Problems & Fixes
107
Sep 28, 2017 09:12 AM
BobbyGraham388
Oct 22, 2015 05:05 PM
Nitin
Sep 30, 2015 08:22 PM
