Can't write Wallpaper to HDD?
Old Jul 5, 2012 | 01:47 PM
greatfolded's Avatar
I found some threads where the HDD wouldn't recognize a USB drive at all, but I have a different problem. The HDD can read the drive, and it lists my .jpg files. But when I select any of them, I get a message saying that it cannot be written to the HDD at this time, try again later.
The images are all from the wallpaper thread here, FWIW.
Old Jul 5, 2012 | 03:03 PM
ucf_bronco's Avatar
I believe only audio files can be loaded to the HDD. You have to load your pics by going through your wallpaper settings and importing them.
Old Jul 5, 2012 | 06:32 PM
Thanks...yeah, I'm going through the Settings > Import menu. It reads the USB drive to identify the images, but when I select them for import, I get an error message that the system can't write to the HDD.
Also, I don't think you can load audio files via USB, either, have to use a CD.
Old Jul 6, 2012 | 12:56 PM
ucf_bronco's Avatar
I don't remember the exact path you follow but try it going through the wallpaper submenu.
I didn't even think about the fact you load the HDD via CD. I actually haven't loaded anything to the HDD yet because my iPod holds all my music.
Old Jul 6, 2012 | 01:18 PM
Thanks...I had the path correct. I tried it with a different flash drive just for grins, and it worked.
As for the HDD, yeah, with and iPod/iPhone, I can't see any reason to load to the HDD. I ripped everything I wanted from my CDs to my iPhone long ago. Next step for me is trying to get some FLACs converted to DVD-A.
Old Sep 7, 2012 | 10:57 AM
sfguy's Avatar
Flacs
I did this, but you have to be careful. Some FLACS have a "watermark" that, when burned to DVD-A, only allows 30 seconds of a song to play. I bought a bunch of FLAC's from HDTracks that were supposedly DRM free, but when I burned them to DVD-Audio, only about 75% of the tracks would burn.
Warner Brothers is the worst for putting this hidden DRM in their FLAC files.
P.S. I had the same issue as you loading .jpg files and thought it had to do with the size of the files, but will try a different memory stick and see if I get better results.
Old Sep 11, 2012 | 07:19 PM
Good to know, thanks....I've got a bunch of FLACs from live shows, so when I get around to this (stalled out/distracted by other things), I'll experiment with those. I'm sure they won't have that. Really have to believe that the net effect of DRM to content producers is not a net positive.
jterp7
3G MDX (2014-2020)
Feb 3, 2016 08:34 PM
Acura604
Sep 28, 2015 12:24 PM
jpadilla
3G RLX (2013+)
Sep 27, 2015 07:53 PM
