Caller Display
Old Sep 18, 2010 | 09:48 AM
caps59's Avatar
Caller Display
Hi all. how do i get incoming calls on my 2010 TL shawd to display caller name and number. i'm using a blackberry bold 9700. thanks, caps59
Old Sep 18, 2010 | 05:12 PM
jabrah's Avatar
MD // NYC
import your phonebook into the system...it should be in the Phone Setup menu...
it'll show up after that
Old Sep 18, 2010 | 05:29 PM
kermitson's Avatar
Yep, load the phone book and it works like a champ!
Old Sep 18, 2010 | 09:26 PM
caps59's Avatar
hi, i loaded the phone book, but when a claller in teh phone book calls, the number only shows up and not the caller's name. what am i doing wrong? j
Old Sep 19, 2010 | 03:07 PM
jabrah's Avatar
MD // NYC
check the prefixes as well as how u entered the phone numbers into your address book...are there dashes between the numbers?
Old Sep 19, 2010 | 03:10 PM
caps59's Avatar
the dashes are there.
Old Sep 19, 2010 | 06:18 PM
jabrah's Avatar
MD // NYC
damn...i have no clue then...it might be something with your phone then...maybe try removing the pairing and repairing it with the car.... If that doesnt work then im not sure what else to try
hope u get it working
Old Sep 20, 2010 | 09:25 AM
normallywho's Avatar
How long are you giving it before picking up the call? I noticed yesterday that a call came in and I glanced over and it just had the number showing and I think it said something like "Searching..." and then a couple seconds later it finally displayed the name. That was probably two or three rings time to display the caller name.
Old Sep 20, 2010 | 02:37 PM
caps59's Avatar
Hi All, I'll let it ring to see if the name appears. Question, how should the prefixes be entered in the phone i.e. +1 (xxx) xxx-xxxx? Thanks for your replies. Caps59
Old Sep 20, 2010 | 03:43 PM
I'm sure the car's logic is doing a simple compare of the incoming phone number to what's in the phonebook. So on your part, the incoming number should match the number for the relevant contact. You probably don't need the leading country code (I don't have it on any of my numbers and it seems to work fine for everything in my phone book).
Old Sep 20, 2010 | 04:26 PM
Samba's Avatar
I have the same Bold 9700. Just enter +1 followed by 10 digits (no dashes, spaces or ()) in your phone number fields and re-import the phone book. It works for me.
Old Sep 21, 2010 | 04:25 PM
Kingmeow's Avatar
Do you have the tech package (only because you didnt' specifically say you have the tech package)? If you don't, it will only display the incoming phone number.
Old Sep 21, 2010 | 08:58 PM
Samba's Avatar
I got the Tech package.
Old Sep 21, 2010 | 09:55 PM
caps59's Avatar
yes i have teh tech package also. i notices callers listed with the +1 prefic with no dashes works great. if you don't have the prefix in front of the numbers, =the caller's name will not appear. thank you all for your help. caps59
Old Sep 23, 2010 | 05:10 AM
clint999's Avatar
Old Sep 23, 2010 | 06:08 PM
jabrah's Avatar
MD // NYC
glad u got it working...that would annoy the $#!t outta me!
Dec 7, 2020 05:39 PM
Feb 25, 2020 09:57 AM
ITSJESTER
17
Dec 6, 2018 02:29 AM
Froid
Sep 27, 2015 06:16 PM
dirleton
Sep 25, 2015 12:25 AM
