Alphabetically order
Im Broke But Im Ok
QUICK question when i put music on my USB an plug it in the car is the music suppose to come up in alphabetically order R it suppose to be mix up
__________________
__________________
The sort is based on some arbitrary OS sort. (Technically it's a list without sorting)
Depending on how technical you are (if you know linux, you're good) you can fix how they are displayed. I was able to do this with my thumbdrive to get everything in order (my files are labeled with the track # 1st).
https://acurazine.com/forums/4g-tl-audio-bluetooth-electronics-navigation-294/usb-flash-drive-help-708421/
The short answer that everyone else is going to give you (and I agree), is go and buy an iPod. I would recommend getting a used 4th Gen or newer iPod from ebay, you can probably get one cheap. You don't need one with a good battery since you can just keep it plugged in all the time.
And, I don't think the Mod's like it when you cross post your question....
emailnatec
29
09-28-2018 04:27 PM
xsilverhawkx
09-28-2015 06:51 PM
