2013 TL Accessory Power Sockets Won't Charge iPhone
Old Jul 8, 2013 | 05:04 PM
Falam II's Avatar
Hello,
I was attempting to charge my iPhone 4S using this product (http://www.powergenbatt.com/PowerGen...&searchSize=12). This product has a blue LED that would turn on when plugged into any vehicle DC socket. When I plugged the PowerGen charger into either of the TL's accessory power sockets, which are located at the front and under the arm rest, the blue LED turns on, but when I plug the USB cable into my iPhone, the iPhone won't charge. The charger is rated at 12 - 24V, 12W, and iPhone charge draws a maximum of 1 ampere, which is well under the "12 volt DC accessories that are rated 120 watts or less (10 amps)" as outlined in the manual.
The charger worked very well when plugged into a 2007 Nissan Altima and a 2003 Toyota Camry.
I don't know a whole lot about vehicle electronics and mechanics, but I don't think it would be a busted fuse, right? Or else the blue LED on the charger won't turn on. Any other possibilities that could be causing this issue?
The iPhone charges fine with the supplied USB adapter cable that is in the vehicle.
Thanks.
Old Nov 7, 2013 | 02:56 AM
Starr_TL's Avatar
Try another one. I can charge two devices at the same time with one of those dual USB 12V adapters
Old Nov 7, 2013 | 09:20 PM
echodigital's Avatar
From TL to RDX
I had a similar issue with a Samsung phone. My iPod and phone would charge when using the cable. It would not charge the phone via 12V adapter. It did non charge the iPod. Weird.
Feb 25, 2020 09:57 AM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
Sep 15, 2015 06:44 PM
ivegotthenav
Sep 11, 2015 07:51 PM
datadr
Sep 2, 2015 06:46 PM
