Your thoughts on the 1/yr or MMS indicator to change oil
What you guys think about the once per year or when Service Due is lit approach regarding oil changes? I am not used to changing oil once a year and am very uncomfortable doing so. My car is 5 months old and at 60% Oil Life. At this rate, I don't think Service Due will be lit within 12 months. I would rather change oil every 6 months. But if I reset oil life prematurely, all the other maintenance sub items will be whacked and inaccurate ( I think)
6spder
1 Post
if they are feeding synthetic oil, its really good for 12k or 12months. i think they run a filter which also supports this.
you should have no problems changing the oil early if u like.
I was told your driving habits and conditions have a huge bearing on your oil life expectancy so I'd add that in, and also that changing oil early is never a bad thing despite what the percentages indicate.
Ditto!!!!!!!!!
As much as it kills me not to change the oil earlier or every 6 months (new generation cars), I would wait for the car to tell you when to do it.
Ditto!!!!!!!!!
Don't you think it will affect the other sub item maintenances? For example: If i change oil 6 months with average of 3k miles. The sub item for air filter will turn on at 15k miles. It will take me 2.5 years to reach 15k miles. Doesn't that mean I won't be changing air filter until 2.5 yrs later? It seems really late. If air filter is based on mileage only, it won't be accurate because I can be in stop and go traffic most of time for the last 2.5 years and that doesn't mean the air filter is not being used just because the car is not moving.
My other questions is whether reseting the oil life prematurely (before 5%) will affect other maintenance codes?
mada51589
05-03-2022 08:54 PM
