Yaw Rate Sensor
Old 10-17-2014, 10:41 PM
jdk714's Avatar
Yaw Rate Sensor
I have 2011 Acura TL AWD Tech . Can you show me Yaw Rate Sensor located? Thanks.
Old 10-20-2014, 03:20 PM
rock the block
lift3d_'s Avatar
why do you need this information? I wish I could help, I'm just curious.
Old 10-20-2014, 03:35 PM
Received 16,266 Likes on 11,974 Posts
Acura Parts @ AcuraOEMparts.com - Genuine Acura OEM Parts from Delray Acura
look in every category till you find it
CerberusKy (10-24-2014)
Old 10-20-2014, 03:36 PM
found it
Old 10-25-2014, 01:44 AM
jdk714's Avatar
I have issue with VSA light turn on... SH-AWD, Check hill assist light also turn on. I was replace VSA module, but turn on the engine then turn back on is disappear .. I think its yaw sensor issue. if you have more information pls lets me know . Thanks
Old 10-25-2014, 05:33 AM
Reorge's Avatar
I think the common system between VSA and Hill Assist is the brakes. Without knowing more information it seems more likely, and easier to tinker with, that your issue might be there. Is the CHECK ENG light on?
I have read about "Acura known" unrelated issues (on my old 99 TL) causing the VSA light to activate (turn on).
Keep us posted on your findings. I'm curious as well.
MrHeeltoe
20
02-23-2023 01:54 PM
RobbDizzle
10-15-2015 11:16 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
thegipper
09-28-2015 01:01 PM
Quick Reply: Yaw Rate Sensor
